2005 07 31
added fix fade-menu option
added fix zapit
2005 07 21 test
added PiP-Demo plugin(DM-7020)
added clock on screen - [tv]key
added support [shift]key + colors keys or [tv] or [radio]
added minimode - [shift]+[red]: blocking main menu and features menu
fix for channels with FEC 7/8
2005 07 15
added support gotoXX/USALS commands for DisEqC 1.2 motors
main menu->service->servicescan->motor-settings
updated tuxcommander
updated tuxtxt
On different channels there is not an exact times.
If there is a file /var/tuxbox/.notimeupdate and the difference of more than 10 minutes, current time does not update.
QuickStart settings.
1. Language Setup, Make your choice and press [Lame/Exit]
2. Main Menu, Settings, Network Settings, Make your choice and press [red]setup network now
3. Main Menu, Settings, Misc settings, Timezone, Make your choice
4. Main Menu, Settings, press [red]save settings now
5. Main Menu, Services, Zapit options, set necessary values and parameters, press [red]save settings
("Re-Zap on emu switch time"-parameter is recommended to put value 5 or 6!)
6. Main Menu, Services, Servicescan, set necessary values and parameters, Scan mode: Fast!,
press [red]save settings, start scan
7. Main Menu, Services, Video Settings, Video system: PAL/PAL-M/NTSC
8. Main Menu, Services, Audio Settings, English: off/on
(switch on english-soundtrack if the "English"-name is present on the channels)
TimeShift settings.
1. Main Menu, Settings, Recording Settings, recording device: direct(file)/off/server
(set to "direct(file)" and set direct recording settings[green], [red]activate changes)
2. Main Menu, Settings, Key Setup, Timeshift, setup new key
(most of keys is not free to use by default, set fee-key(example,bouquet+-) or change non-free
to free before start to set timeshift-key)
3. Main Menu, Settings, Movieplayer Settings, Timeshift pause: on/off
("on" - timeshift starting record and stop movieplyer to pause, "off" - timeshift starting record
and play continue)
4. Main Menu, Addons, Emu Type, Camd: no/mgcamd/newcamd/camd3/scam
(Timeshift supporting mgcamd/newcamd/camd3/scam emu for crypt-channels)
Scripts.
Main Menu, Scripts
1. Autoconvert/autoconvert settings format
(puting lazymax settings files to box and start script, all settings will be convert to "nlpus"-format)
2. Reset EPG
3. Readme 1st/Image info
4. Satfind bg/signal monitoring tool (DM-7000/7020)
Default Keys(buttons)
1. [dream/menu] - Main Menu
2. [blue] - Features
3. [help] - channel info
4. [help][help] - channel EPG
5. [help][help][help] - channel EPG bigest font size
6. [help][help][help][help] - channel EPG normal font size
7. [info] - channel info (same as [help])
8. [video] - Movieplayer
9. [audio] - Audioplayer
10. [green] - Select language
11. [red] - EPG Programm Information
להורדה כאן
