* Displays Picture-In-Picture (PIP) with two HD services
* Plays back media contents of Youtube
* Provides a network game named BATTLE TANK
* Plays back video files of DivX
Features
* Is fully compliant with DVB-S and DVB-S2
* Supports DiSEqC 1.0, 1.1, 1.2 and USALS
* Can store up to 7,000 TV services and 3,000 radio services
* Supports time-shift up to 5 hours at maximum
* Records two services at the same time while displaying another service
* Can record directly to an external hard drive as well as the built-in hard drive (Using USB/eSATA ports)
* Plays back recorded programmes at up to 64 times speed at maximum
* Displays image files of JPEG
* Can search and view a image file in the Flickr
* Can see the weather of cities.
* Provides various ways for firmware update (OTA, USB, LAN)
* Enables you to use the receiver as a web server and a FTP server
* Supports MediaHighway EPG
Specification
DVB Compliant A/V Decoding
Transport Stream ISO/IEC 138-18 MPEG-2, H.264/AVC Aspect Ratio 4:3, 16:9 Video Resolution 576i, 576p, 720p, 1080i Front Panel
**** 1 *** (POWER) and 6 **** (Touch sensor) VFD Service number, name, or time display A/V & Data In/Out
HDMI HD Video/Audio output TV-Scart Video CVBS/S-VIDEO/RGB/YPbPr output
Audio L/R output VCR-Scart Video CVBS output
Audio L/R output
Video CVBS/S-VIDEO/RGB/YPbPr input for bypass
Audio L/R input for bypass RCA A/V Video (YPbPr), Video (CVBS), Audio (L/R) output S/PDIF Digital audio output USB USB 2.0 Host LAN 10/100 Ethernet eSATA, HDMI PAL B/G (External Hard Disk Drive) Power Supply
Input Voltage 90 ~ 250VAC, 50/60Hz Type SMPS Power Comsumption Running: Max. 60W, Standby: 7W Physical Specification
Size(W x H x D) 340 x 82 x 258 mm Weight(Net) 3.8Kg
650
הממיר החדש של טופילד SRM-2100
- הודעות: 2331
- הצטרף: 29 ינואר 2008, 08:17
- הודעות: 4
- הצטרף: 01 אוקטובר 2011, 13:40
