Gemini החדש לדרים 7025
קבצים ולינקים המיועדים ל 7025 בלבד
adiga
הודעות: 690
הצטרף: 07 אוגוסט 2004, 17:47
שליחה על ידי adiga » 31 מאי 2006, 09:12
Gemini2 v1.50:
Technical Infos:
* Enigma from: 16.05.2006
* GCC 3.4.5 Original CVS
* Busybox 1.01
* Kernel 2.6.12.6
Function Buttons:
* BLUE - Blue Panel (BP)
* RED - Record
* GREEN - Subservices
Features:
* Own Addon-Server via internet
* Downloading and installation of additional features via internet from Gemini server
* EMM- und ECM- Display switchable
* Behaviour of infobar can be changed via Menu
* System Info: Many extra box infos (for example harddisk-temperature, storage usage, mountpoints)
* Extra Menu: Settings to many extras like Inadyn, HTTPD, NFS-Server, calendar
* Own Scripts can be started via Blue Panel
* Calendar including reminder (can be changed via /etc/calendar.xml)
* Dreambox can be used as printserver
* Kernel modules can be reload separately
* Support for CDROM/DVD, no matter if IDE or USB port
* Display of current channel stream rates
* SWAP setup and start automatically
* HDPARM values for harddisk can be changed via menu
* Storage location of epg.dat can be changed via menu
* Displaying CaID´s in the Infobar
* Change the password out from menu
* Autocamd
New:
* camd script can be edited
* Hdd-Performance
Fix:
* camd user name was not indicated
* The reminder doesn´t work if the event occours on the 1th
* satellites.xml only approx. 140kb were created
Attention:
* Do not use old Gemini2 skins!
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Download via Database
Thanks a lot and have fun
Your Gemini-Team
My Webpage
תמונהתמונה
[ART+ORBIT+SHOWTIME]
