dreambox 8000
adiga
הודעות: 690
הצטרף: 07 אוגוסט 2004, 17:47
שליחה על ידי adiga »
DM 8000
To be released later this year a first look at the dreambox dm8000 ,it has 723 mhz ibm a processor, is with 2 ci card locations and 2 integrated card readers and inserted dvd drive assembly, so that one directly dvds also on non removable disk to take up can. the non removable disk is inserted now in series, it gives the new railways of 80-300 gb. the power pack is again revised and has sufficient achievement, so that no second will be more necessary. and beside the new usb 2,0 card location, serial connection , network map, is 10 a subject card reader now in front, so that all possible data, photo, mp3 directly on the non removable disk to be pulled can. the display increased on 3,5x 5.5 cm. linux remains naturally the operating system, however in a new to be able to use version,um all features. keep looking here as more info will be added as we find out more about this beauty
Specifications
Twin tuner (optional card)
Linux open SOURCE
DVI, HDMI
Hardware MPEG2, MPEG4/H.264 & WM9 (HDTV compliant)
300Mhz MIPS CPU
128 Mb RAM
32 Mb Flash
100 MBit full duplex Ethernet interface
MiniPCI slot
Super cool display (RGB color adjustable)
slimline DVD player (optional)
HDD (optional)
2 x CI, with eject button
2 x smartcard reader & 1 simmcard reader (internal)
Multiple layer 3D menu (16 milion colors)
USB 2.0
אמרו שזה עולה 800 יורו
תמונהתמונה
[ART+ORBIT+SHOWTIME]
