hello guys
i have a magnum legend receiver.o
can someone explain me what the use of ANT IN and RF OUT ?o
thx a lot
ANT IN and RF OUT??
yanivasy
- הודעות: 255
- הצטרף: 04 ינואר 2007, 11:00
If you are using an aerial antenna you can connect it to the ANT in terminal.
If you television is very old and isn't equipment with AV input termainal then you can connect the RF out to the Ant input of the television set.
If you have more then one T.V. then you can connect them to the RF out terminal.
zebulon
- הודעות: 37
- הצטרף: 22 נובמבר 2005, 10:36
yanivasy
- הודעות: 255
