תוכנות עריכת ערוצים - Dreamset,OpenDBEdit...
yhaddad
הודעות: 1391
הצטרף: 12 מרץ 2004, 21:08
מיקום: מרכז
שליחה על ידי yhaddad »
DreamBoxEdit 1.87.00
- Fixed error with "Copy & Edit service" option
- Renumber services function reinstalled
- Fixed problem with multiple delete of (user)bouquets
גרסה חדשה למטה
yhaddad
הודעות: 1391
מיקום: מרכז
DreamSet 1.61
Fast, multilanguage Settings Editor For DreamBox.
* Edit Settings:
* Enigma settings.
* Neutrino settings.
Go to setup dialog to configure DreamBox IP address and Firmware.
* View - Import Settings from:
* Neutrino
* Enigma
* Triple Dragon
* Nokia 9800s/9902s Files (m9
* LyngSat script files (dat)
* SatcoDx(sdx)
* DVB (dvb)
* Humax (hnf)
* Other Features:
* Organize bouquets and user favorite lists (Add/Remove/Arrange lists and channels).
Flexible User Interface multi selected Drag & Drop.
* User defined Sorting of services in a list/bouquet
* Markers support.
* Multilanguage List/Service names editing.
* Add/Edit/Delete Satellites, Providers/Networks, Transponders and Channels.
* Copy/Paste channels
* Drag & Drop Providers, Tranponders, Channels
* Import Favorite Lists from other settings like DreamBox,Nokia 9800,Humax.
* Export Favorite Lists to a special format compatible for Dreamset to import back your lists.
* Export Settings as HTML and as Lyngsat files.
* DreamBox registry editor.
* Multilanguage User Interface support.
30/12/2005 - ver 1.61 final
Added. Multiple Box configuration. Now you can define more than one
boxes and switch between them with one click.
Added. At Setup->Preferences, option to start Dreamset minimized to tray with
windows startup.
Fixed. Triple Dragon, trasponder properies, nid and tid attributes was incorrect.
Fixed. Neutrino, you can set DiseqC port for satellite at
'Edit Settings' -> 'Satellite Properties'
Updated. dreamset.dnl with more Satcodx positions (thanks EnoSat)
Updated. mmedit.db, updated info for bouquets and services from LyngSat web pages.
גרסה חדשה למטה
DreamBoxEdit V1.90.00
- Preliminary support for the Dreambox 7025 (which uses a new version settings formats / filenames)
- Allow for IP names (like "MyDreambox.dyndns.com") instead of only numeric IP addresses
- Main screen panel widths are now saved
- The widths of the columns within lists (main screen) are saved
- The "delete bouquets with 1 service" popup menu option is changed to "delete bouquets with x services"
גרסה חדשה למטה
DreamSet 1.63
29/01/2006 - ver 1.63
Update: Increase size of internal structures to hold more elements.
Added: Configuration Name at status bar.
Fixed: Delay when sorting.services.
Fixed: Incorrect sorting by sat position
Fixed: Temporary files did not removed after executing Telenet/Http commands.
DreamBoxEdit V2.0
New in version 2.00.00:
- Support for multiple tuners (satellite, terrestrial and cable) for the Dreambox 7025
- Re-import services from exported services file
- Menu option for (repeat) search
- Password optional as hidden field
- "insert copy of above transponder" option in satellites.xml editor screen
- Check on valid SID/NID/TSID when exporting services to SatcoDX format
- Better handling of flags in packagename field
- Fixed error where program hangs when a bouquet file is empty
- Bug fix in version checking
יש לשים לב להודעה שמתקבלת כשמפעילים את התוכנה ולקרוא בעיון לפני שמאשרים
גרסה חדשה למטה
DreamBoxEdit V2.01
עדכונים:
- terrestrial.xml and cables.xml are now retreived from and sent to the Dreambox just like the satellites.xml
- Fixed error with "Copy & Edit service" option, where the new service was always saved as cable service
גרסה חדשה למטה
DreamBoxEdit V2.02
DreamSet 2.13
raveyd
הודעות: 1486
הצטרף: 14 מאי 2005, 17:25
שליחה על ידי raveyd »
אנשים טובים באמצע הדרך
וויזנט 9510 HD
raveyd
הודעות: 1486
ישנו 2.15
מישהו יכול לעלות בבקשה?
וויזנט 9510 HD
winnee
הודעות: 99
הצטרף: 03 דצמבר 2007, 10:34
שליחה על ידי winnee »
2.15
“If the person you are talking to doesn't appear to be listening, be patient. It may simply be that he has a small piece of fluff in his ear.”
yoramro
הודעות: 1278
הצטרף: 04 ספטמבר 2004, 20:00
שליחה על ידי yoramro »
OpenDBedit 3.0.6
Dreamset 2.18
17/09/2008 - ver 2.18
Added: Write support for Enigma2 settings version 4.
Added: Check configuration reports the box settings version (only for enigma 2)
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
3.0.0.5
- removed settings-type 3 from options panel (no longer needed all E2-Boxes working with settings-type 4)
- added button with terrestrial path settings (E1) to options panel
- fixed settings-type switching via menu -> tools -> toggle between version 2 and 4 settings
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
DreamBoxEdit 4.1.0.0
Quote:
Changelog:
4.1.0.0
- added crypto icon in main service list if service is encrypted (Note: this is only working properly on future Enigma2 Images)
- added filter for encrypted and unencrypted services (Note: this is only working properly on future Enigma2 Images)
- added copy service reference to clipboard option to context menu of main service list and bouquet panel
- added a info window with some informations about the new filtering behaviour
- fixed error message when using picon cleanup function and filename wasn't using proper picon reference format
- fixed error message when using add new service option in context menu
- fixed application hanging when parsing lamedb with corrupted transponder entry
- fixed problems after adding new services, the services weren't covered by the filters
- some minor fixes
- language files updated
http://www.skystar.org/comment.php?dlid ... d71d4a79f3
NGC224
הודעות: 338
הצטרף: 11 מאי 2011, 22:52
שליחה על ידי NGC224 »
אני הורדתי את DreamBoxEdit
ואין לי שם ערוצים...
משהו יכול להסביר איך מתחברים לדרים ואיך משתמשים בתוכנה ?
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
עידכון נוסך 5.0.0.1
DreamboxEDIT 5.0.0.1
Quote:
Changelog:
- fixed compatibility problems when running dreamboxEDIT under wine
Note: skinning support is automatically disabled, Wine 1.3.34 or higher is mandatory
- some language file updates
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
yossid
הודעות: 1112
הצטרף: 14 ספטמבר 2006, 13:53
שליחה על ידי yossid »
m8m8 @ 4/12/2011, 19:39 כתב: עידכון נוסך 5.0.0.1
Quote:
Changelog:
בגירסה הזאות ניתן להוסיף שפה
לחיצה על עזרה ויש עורך שפה ואפשר שם לשנות כל שפה לעברית
בברכה
יוסי
