Gemini 4.10
yoramro
הודעות: 1278
הצטרף: 04 ספטמבר 2004, 20:00
שליחה על ידי yoramro »
מהאתר:
http://www.i-have-a-dreambox.com/wbb2/index.php
מחייב הרשמה לאתר כדי להוריד.
טרם הספקתי לבדוק
אלה השינויים:
Gemini2 v4.1
DM7025 = Enigma from 06.02.2009
DM800 and DM8000 = Enigma from 07.02.2009
Most Functions are described in our Wiki.
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* long BLUE -> PiP (DM7025)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED -> File Manager
* RED - Record
* GREEN - Quickbutton / Subservices
* Yellow - Timeshift (not for DM8000)
Extras:
* Own Addon-Server via internet.
* Cryptinfos of the Stations. Assign different Camds to Stations/Providers (AutoCam).
* Manage many Daemons / Server (BP - Services/Daemons)
* Visual improvements such as HD-Skin, icons or additional adjustments to the station list
* Manager for formatting, setting up or integration of devices (BP-> Device Manager)
* additional EPG functions, such as Autosave, Refresh, or connect different EPG formats
* Own Addons e.g. Dreamnetcast, jukebox, calendar, e-mail or eTorrent to name just a few
* Quick button (select the function of the green button via the menu)
* detailed information about your Dreambox (Menu-> information)
* File Manager, it is possible to handle all formats, regardless of whether images, sound, film material, playlists, Torrents, scripts or DVDs (BP-> File Manager)
Many other functions, such as "the GP2 Controlr" Rezapp or the many options can in IHAD board or our Wiki to be read.
New:
* File-Manager extended (Information, display and favourites). It´s now eaysier to achieve, simply press BLUE-RED
* In the channel list, the distance between the stations and the actual EPG event can be changed by yourself (BP-> Settings-> General)
* At Dreamnetcast and the jukebox you can chose the background
* Menu´s extra/settings seperated. BP has partly new construction (Addons are now at BP-> Settings to find)
* Discrete OFF(Standby) by shift-0, ON by shift-1, OFF (Deep Standby) by shift-2 (DM8000 not with original Remotecontrol)
Fix + Update:
* Formatting the Harddisk
* Dreamnetcast, Jukebox
* see CVS
Known problems:
* Bootpictures
* fast changing of tracks in the jukebox when covers from internet is activated
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not from us
and won't be supported!
Download via Database
michagold
הודעות: 542
הצטרף: 01 אוגוסט 2005, 23:56
שליחה על ידי michagold »
האם ניסתי את הגרסא הזו? להתקין אותה?
האם השיטה המוסברת במדריך הזה IMAGE עובדת טוב?
yoramro
הודעות: 1278
טרם הספקתי לבדוק.
בעיקרון אני בודק גירסאות חדשות עם Barry Allen שמאפשר התקנת מספר אימג'ים שונים על Disk פנימי או חיצוני (כולל Diskonkey) ולבחור בינהם. זה לא נוגע ב Flash במכשיר. אם לא מרוצים מה-Image החדש - מוחקים אותו וממשיכים להשתמש ב Image אחר.
השיטה שנתת אליה לינק היא השיטה המומלצת והמהירה ביותר לטעינת Image אל ה Flash בתוך המכשיר.
max2003
הודעות: 480
הצטרף: 24 דצמבר 2003, 01:28
שליחה על ידי max2003 »
ואי אפשר להוריד ישירות מאחד מתפריטי ה add ons של המכשיר?
להוריד מה, אימג? ממש לא
max2003
הודעות: 480
או קיי, אשמח לשמוע ממי שהתקין אם יש שיפור במשהו משמעותי
