ממיר HDTV עד 1500 שקל ?
DJ
- הודעות: 732
- הצטרף: 23 ספטמבר 2004, 18:08
- מיקום: תל אביב
Bori4ka
- הודעות: 153
- הצטרף: 27 אפריל 2008, 17:46
- מיקום: אשדוד
DJ
- הודעות: 732
- מיקום: תל אביב
Bori4ka
- הודעות: 153
- מיקום: אשדוד
טוב אז זה הממיר (בלי פרסום לאתרים)
HD Receiver Model KV801
Incorporating the highly integrated single chip, KV801 is a high performance digital satellite HD receiver supporting H.264 and MPEG4. KV801 provides channels with user-friendly OSD (On Screen Display) and stores up to 5000 channels with fast inter-channel switching capability, which undoubtedly makes it an ideal choice for viewers like you to enjoy the digital life. High performance digital audio is also available through S/PDIF. Features : Fully DVBS2 / H.264 & MPEG -2 compliant
32Bit CPU : STi 7100 6M Flash & 128MB DDR-RAM 5000 channels memory space Compatible with 480/576i/576p/720p/1080i video formats Aspect ratio 16:9 and 4:3 16bit colors OSD supported AV Output : HDMI, YPbPr, RCA, Dual Scart , S/P DIF Multi-language Subtitle output supported 7 days Electronic Program Guide (EPG) Common Interface slot ready (Single CI ) Teletext output through VBI and OSD Picture in Picture (PIP) supported( optional) NIT search supported Channel search in automatic, manual and network search Software upgrade via RS-232 serial port Timer function supported USB 2.0 interface supported (Front) TUNER DVB-S2 : Input Frequency: 950~2150MHz Loop Out Frequency: 950~2150MHz Input Level: -65~ -25dBm Input Impedance: 75 LNB Power :13,5V/18,5V/OFF, Imax = 500mA DiSEqC: 1.0 & 1.2 AV OUTPUT : Video De-emphasis:CCIR REC.405-1, 625LINES Video Bandwidth: 5.5MHz Video Output Impedance: 75 Video Output Level: 1.0Vp-p Audio Output Frequency: 20Hz~ 20KHz MEMORY : Flash Memory: 6MB SDRAM Memory: 128MB (4 * 32 MB) CHANNEL DECODING : Standard: DVB S2 . Demodulation: [DVB-S]: >Symbol rate=2~45MSps >FEC:1/2,2/3,3/4,5/6,6/7,7/8 [DVB-S2]: >Symbol rate=QPSK 10~30MSps and 8 psk FRONT PANEL IR Receiver: 38KHz USB 2.0 Interface 1 CI Slot
מחיר 1385 ש"ח
מישהו יודע עם הממיר הזה איכותי?
מחיר 1385 ש"ח
Mutant S200 ו- OpenBox 300
Abs1 ו- HotBird ו- Sirius
AB COM
AB COM
DJ
- הודעות: 732
- מיקום: תל אביב
- cavtl
- מתקין
- הודעות: 2301
- הצטרף: 21 מרץ 2004, 08:49
בחנות שבראש הפורום יש ממיר שכולל חיבור לאינטרנט במחיר סביר של 2100 ש"ח הרבה יותר טוב מאשר ממיר וכאם קישורhttp://www.satshop.co.il/hdtv.cfm
- marcelos
- הודעות: 1028
- הצטרף: 11 פברואר 2005, 09:54
- מיקום: קרוב, בסביבה
DJ
- הודעות: 732
- מיקום: תל אביב
- tiptip
- הודעות: 1691
- הצטרף: 15 מאי 2007, 20:29
- tiptip
- הודעות: 1691
אשמח גם לדעת אם מישהו מכיר את הממיר הנ"ל המכיר מפתעBori4ka @ 25/3/2009, 21:11 כתב: טוב אז זה הממיר (בלי פרסום לאתרים)
מחיר 1385 ש"ח
dream 800 hd
26E 19.2E 16E 13E 7E
9E 5E 4W 7w
אור שפע ואהבה!!!
9E 5E 4W 7w
אור שפע ואהבה!!!
DJ
- הודעות: 732
- מיקום: תל אביב
- tiptip
- הודעות: 1691
DJ
- הודעות: 732
- מיקום: תל אביב
