Special Design for Receiver with DiSEqC 1.2 & UASLS
66 satellite Positions Memory
Only One Coaxial Cable Control
Automatical calculation of the satellite positions(Go To X Function)
High Efficiency
Compact Structure
Ultra Low Noise
Adjustable Hardware Limits
Easy Installation with LED Indicator
Manual EAST / WEST Two Buttons
For Dish up to 1.8M
* Everything is controlled via only one coaxial cable;
* Specially designed for receiver with DiSEqC1.2 receivers or USALS receivers;
* 66 easy programmable satellite positions;
* Drive dish up to 180cm;
* Azimuth angle up to 100 degree (50E~50W);
* Elevation angle up to 50 degree (30~80 degrees);
* Programmable East / West software limits; and double software limit protection;
* Manual East / West two buttons; Easy manual operation;
* Orientation angle: <0.1 degree;
* Goto x function or USALS compatible;
* Goto 0 degree by manual buttons, and double color LED aptitude indicator for easy installation;
* System Reset & Re-Setting reference 0 degree position via button;
* High efficiency designed, ultra low noise, compact structure;
* Exact position, no sway clearance, no lose memory;
* The best and advanced software designed, the newest MUC, more excellent and safety;
* Motor consumption: 14/18VDC, @350mA (Max); 250mA (Normal); @50mA (Standby).
