Today is new SWF Vizyon out. Transfered from Minicats forum. Thanks to SwennaDeluxe.
Interested image based on Tideglo rev.0.7.5 with some interested solution about pasnel-cam menagement, and predefined cams, and much more...Easy to install. Whats new?
release 0.7.5
- added possibility to search channels by channel name's first letter, just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connect other devices to the box and see automatically the TV signal when cuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in the A/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels (like Universal Channel with Romanian subtitles, TotalTV and so on: report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on some channels (like Mega, Star, ANT1 in package Netmed: report if now it works good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
SWF MOD :
- eigenes SWF-Panel
- Bootlogo geändert
- cardreader support
- swf-panel installierbar (script-executer)
- Enigma2.mo angepasst auf vizyon
- Telnet-login überarbeitet (root / vizyon)
- Videotext auf Wunsch nun Vollbild
- png im Webinterface getauscht (webtv)
- Web-Interface Style geändert
- incubus 0.96, mbox , camd3 mgcamd sind bereits enthalten ( Blue Panel )
Danke an mcron und alle Tester
-User = root
-Passw.= vizyon
Password can easy change in panel. Very easy to menage cams, rešplace only a couple of files with your own.
I not so much tested, only about a half of hour, but look at stable.
Cheers
acer2
SWF-Vizyon-8x0/0-E2_V2.0
-User = root
-Passw.= vizyon
not really, here are the links:
IP-Box 91HD ( 250HD )
USB
http://np-ulc.net//index.php?action=dow ... 50HD%20%29&
Flash
IP-Box 900HD ( Mini )
USB
http://np-ulc.net//index.php?action=dow ... Mini%20%29&
Flash
http://np-ulc.net//index.php?action=d ... 900HD%20%28%20Mini%20%29&
IP-Box 910HD ( Mini2, 3000HD )
USB
http://np-ulc.net//index.php?action=dow ... 00HD%20%29&
Flash
IP-Box 9000HD
USB
http://np-ulc.net//index.php?action=dow ... x%209000HD&
Flash
found the links at RSP Forum by PETER36. so credits to them.
Thanks to SWF for this image, will try it soon!
						SWF Vizyon 80../ipbpx90..E2_V2.0 for flash and usb
- הודעות: 2791
