למה אף אחד לא מגיב<:?
raz251
- הודעות: 44
- הצטרף: 25 דצמבר 2003, 20:38
- שלמה רוזן
- הודעות: 2621
- הצטרף: 22 דצמבר 2003, 23:15
רז אני מקוה שאתה קורא אנגלית,
Posted: Fri Sep 17, 2004 3:05 pm Post subject: Guide How to Patch Humax with HoT Emu
During all time there is always someone who needs a step by step guide how to.
Taken from Delphi and amended by me for hot use.
This is to help new users:
First download Humax Toolbox by Mr Dude. This is a very good toolbox which contains all necessary tools for uploading, firmware, key.bin, PMCT etc etc. Alternatively you can download separately and use tools that you might need.
1. Install Toolbox into your PC
2. Download the +CAM firmware: ( HoT emu xx)
This is the software you have to upload in your receiver in order to have the multi-CAM mode. Its a file with the extension HDF, and is created by ToH/HoT team.
3. Prepare for installing :
3.1. Turn off your Humax (so put it in STAND-BY modus) the card you used up to now it should be in the slot all the time.
3.2. Connect your PC to the STB using a RS-232C null modem cable
3.3 Start the Humax Uploader program (HU15.EXE from step 2), and set up the correct COM port and baud rate
3.4 When you click on humax uploader, 'Open HDF File' choose the HDF file you have downloaded and unzipped at step number 2. An automatic integrity check out is done through the file, next windows should appear if the file it's authentic and OK
4.Start installation of new firmware:
4.1 If everything was setup correct, click the 'Upload [PC->STB]' button. You need to turn on the Humax from Stand-by button manually to have the download started. During the process, you should see a progress bar.
4.2 After 100% a screen opens and tells you to turn on your Humax. The display will show a blinking END word. Push the Stand-by button again.
5.From the receiver remote control, select 'Menu' ->'Config'-> Select Emu or Emu-K instead of Card
Uploading the Key.Bin
1. Download the latest key.bin and unzip then in you preferable folder
2. Start your humax in a channel (preferably FTA channel)
3. Connect you PC with Humax by RS-232C null modem cable
4. Open Humax Toolbox, click on DRS9500 EmuEd xx or S+Humy Edit xx, File Open File and point to the saved unzipped key bin (see 1). Press open Write, you
who dares wins
raz251
- הודעות: 44
שלמה תסלח לי שלא הסברתי נכון את השאלה אני יודע איך לעדכן את הממיר הבעייה שלי ושוב אני אסביר אותה.
הצלחת שלי נשארה אצל אבי בבית אצלו אין מחשב והוא גם לא מסוגל להתעסק עם כל הקבצים והיות ואצלי כרגע אין צלחת אז מה שביקשתי בסך הכל זה לדעת אם יש פא'ץ עדכני שמסוגל לעבות עם פאנכארד כמו שהיה בשנתיים האחרונות מבלי שום שיכות לשיתוף ולקבצי BIN אני מקווה שסוף סוף מישהו הבין את השאלה שלי ואם יש כזה פא'ץ אשמח אם תפנו אותי אליו.
ariel
- הודעות: 1419
- הצטרף: 24 דצמבר 2003, 11:02
- שלמה רוזן
- הודעות: 2621
raz251
- הודעות: 44
- שלמה רוזן
- הודעות: 2621
raz251
- הודעות: 44
- שלמה רוזן
- הודעות: 2621
