The Gemini2 Project 5.00
ahgi
הודעות: 3742
הצטרף: 07 ינואר 2004, 17:38
Has thanked: 31 פעמים
שליחה על ידי ahgi »
גימיני 5.0 לממיר סיני
 OE1.6
  Real SSL76, you can use the latest official driver.
  Suitable for all SIM2.01 CLONE DM800.
  Function Buttons:
  * BLUE - Blue Panel (BP)
  * BLUE long - Picture in Picture (DM7025, DM8000)
  * 2x BLUE - BP -> Gemini Extras
  * BLUE RED - File-Manager
  * RED - Recording (not for DM8000)
  * GREEN - Quickbutton / Subservices
  * YELLOW - Timeshift (not for DM8000)
  Extras:
  * Addon and Plugin Server
  * Cryptinfos of the channel or Cam, Stick Cam to certain channels
  * Function for managing many daemons / server (BP -> Services/Daemons)
  * optical enhancements like HD-skin, additional icons or modification of the channel list
  * Manager for format, setup or mount devices (BP -> Device-manager)
  * Additional EPG-functionality like Autosave, Refresh or different EPG-format view
  * Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
  * Quickbutton, to define functionality of the Green button via menun
  * Detailled information about your Dreambox (Menu -> Information)
  * File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
  * complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
  Information about many other functions can be found at the IhaD-Board or our Wiki.
  New:
  * Adaptions for 500HD
  * Change to OE1.6, new kernel version
  * FTP-Mounts - Mounts FTP-Servers as directories into the system (BP->Extras->FTP-Mount)
  * new widget, animations (GIFs) in the skin
  * ext2 or ext3 selectable if initialize
  * The expert line in the infobar can be configured now
  * Standby for USB-Harddisks (Attention: Doesn‘t work with all conrtolers)
  * Device-Manager partially very strong revised
  Fixes + Updates:
  * Email-Checker fixed, can handle Googlemail accounts again, and no Enigma2 crash if no SSL-Connection can be done.
  * The Stream-Traffic-Info should work better now on HD-Channels
  * Selectable quickbuttonfunctions extended
  * Weather
  * see CVS
  Important:
  Attention on some harddisks the new kernel may cause problems.
  * On the DM8000 from the beta-series, a security chip update will maybe make a second boot necessary.
  This image doesn‘t contain any keys or softcams!
  Backups or other modified images are not released by us
  and won‘t be supported in any way!!!
http://www.1clone.net/gemini5.0.rar
מילה טובה לא עולה כסף
ahgi
הודעות: 3742
שליחה על ידי ahgi »
Gemini 5.1 For Dreambox800HD
http://www.1clone.net/gemini5.1.rar
ahgi
הודעות: 3742
שליחה על ידי ahgi »
התקנתי 5.0 עובד יציב |כן|
seank
הודעות: 203
הצטרף: 14 מאי 2006, 14:29
שליחה על ידי seank »
5 בהחלט יציב , אבל לא משפר את מהירות התפקוד בתפריטים.
ahgi
הודעות: 3742
שליחה על ידי ahgi »
ניסית 5.1?
seank
הודעות: 203
לא.....
dmsat
הודעות: 2031
הצטרף: 17 ספטמבר 2005, 01:49
שליחה על ידי dmsat »
לשים לב, בגימיני 5.0 התוספים לסקינים תחת ה BLUE PANEL - גורמים לאיתחול ציקלי ומחייב
פלאש מחדש !!
אם לא משחקים בסקינים יותר מדי אז בהחלט הגימיני 5.0 יציב מאוד.
אך יש תופעת ה TUNER FAIL .
הודעות: 30816
TUNE FAIL עם טיונר מקורי?
