bogyman
הודעות: 561 הצטרף: 11 יולי 2005, 10:09
שליחה
על ידי bogyman » 04 יולי 2011, 08:24
קוד: בחירת הכל
>> OSCam << cardserver started at Thu Jan 1 03:05:45 1970
1970/01/01 3:05:45 227 s version=0.99.4svn.r517.p2, system=powerpc-dreambox-linux, nice=-1
1970/01/01 3:05:45 227 s max. clients=29, client max. idle=120 sec
1970/01/01 3:05:45 227 s max. logsize=unlimited
1970/01/01 3:05:45 227 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
1970/01/01 3:05:45 227 s shared memory initialized (size=406376, fd=3)
1970/01/01 3:05:45 227 s auth size=4736
1970/01/01 3:05:45 227 s Cannot open file "/var/tuxbox/config/oscam.services" (errno=2)
1970/01/01 3:05:45 227 s userdb reloaded: 0 accounts freed, 1 accounts loaded
1970/01/01 3:05:45 227 s signal handling initialized (type=sysv)
1970/01/01 3:05:45 227 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
1970/01/01 3:05:45 227 s monitor: disabled
1970/01/01 3:05:45 227 s camd 3.3x: disabled
1970/01/01 3:05:45 227 s camd 3.5x: disabled
1970/01/01 3:05:45 227 s cs378x: disabled
1970/01/01 3:05:45 227 s newcamd: initialized (fd=7, port=34000, crypted)
1970/01/01 3:05:45 227 s CAID: 0B00
1970/01/01 3:05:45 227 s provid #0: 000000
1970/01/01 3:05:45 227 s radegast: disabled
1970/01/01 3:05:45 227 s resolver thread started
1970/01/01 3:05:45 227 s logger started (pid=229)
1970/01/01 3:05:45 227 s resolver started (pid=230, delay=30 sec)
1970/01/01 3:05:45 227 s reader started (pid=231, device=/dev/sci0)
1970/01/01 3:05:45 227 s Waiting for local card init ....
1970/01/01 3:05:45 231 r02 card detected
1970/01/01 3:05:47 231 r02 ATR: 3B 34 94 00 30 42 30 30
1970/01/01 3:05:48 231 r02 type: conax, caid: 0B00, serial: 0, card: v0
1970/01/01 3:05:48 231 r02 Conax-Provider:0
1970/01/01 3:05:48 231 r02 ready for requests
1970/01/01 3:05:48 231 r02 card detected
1970/01/01 3:05:49 227 s Init for all local cards done !
1970/01/01 3:05:49 227 s anti cascading disabled
1970/01/01 3:05:49 227 s client(1) connect from 192.168.1.115 (pid=232, pipfd=12)
1970/01/01 3:05:49 232 c01 encrypted newcamd:34000-client 192.168.1.115 granted (amjad, au=mbchd)
1970/01/01 3:05:49 232 c01 user amjad authenticated successfully (using client 6D67)
1970/01/01 3:05:49 232 c01 AU flag 0 for user amjad
1970/01/01 3:05:51 232 c01 amjad (0B00&000000/0002/67:3C31): not found (1820 ms)
1970/01/01 3:05:54 232 c01 amjad (0B00&000000/0002/67:3C31): not
assem
הודעות: 478 הצטרף: 05 ינואר 2008, 22:20
שליחה
על ידי assem » 04 יולי 2011, 12:23
לא הבנתי בדיוק מה הכוונה,
זה כבר בשיתוף או שזה מתוך הממיר המקורי שלהם?
DM 800 SE - 4w-7w-13e-26e
יחיה השיתוף ! מכור לערוצי HD
הודעות: 30825 הצטרף: 22 דצמבר 2003, 22:54
Has thanked: 11 פעמים
Been thanked: 45 פעמים
שליחה
על ידי י א » 04 יולי 2011, 16:33
יש שמועות ברורות שזה ניתן לשיתוף
הודעות: 2584 הצטרף: 13 יוני 2010, 14:46
Been thanked: 8 פעמים
שליחה
על ידי gilad2211 » 04 יולי 2011, 18:50
רגע רגע לא הבנתי כבר התחילו השידורים? נעלמו הפרומואים? לא בדקתי את הערוצים הללו הרבה זמן.
ממיר AZBOX PREMIUM HD+
thestalker
הודעות: 2183 הצטרף: 21 פברואר 2004, 16:35
מיקום: ראשל"צ
Been thanked: 5 פעמים
שליחה
על ידי thestalker » 04 יולי 2011, 19:31
14 שורות של סרברים ואף אחד לא פותח לי את זה
יש לי 1.8 ממונעת מ30W עד 42E
ממיר עם מנוי חוקי ל CSAT
bogyman
שליחה
על ידי bogyman » 04 יולי 2011, 19:50
bogyman
שליחה
על ידי bogyman » 06 יולי 2011, 18:55
עדכון חשוב !!!!!!!!!!!!!
MBC אכן משתמשים card marraige אבל רק אם נעשה לכרטיס אקטיבציה ראשונה בתוך הממיר
ואז הכרטיס לא יעבוד בשיתוף , אם היה לכם מזל וקיבלתם ממיר חדש והדילר לא נגע בו
1) יש לעשות אקטיבציה עם ממיר מובנה קונקס או CAM (אם היה לי את הכרטיס בטוח הייתי משתמש ב SCAM )
2) ולהשתמש ב newcs 1.17 = boxid-0000000
zweiss
הודעות: 2162 הצטרף: 25 דצמבר 2003, 15:22
שליחה
על ידי zweiss » 06 יולי 2011, 19:34
י א @ 4/7/2011, 16:33 כתב:
ממתי?
כרגע המסכים חשוכים...
1.2m=7W,4W,9E,13E,16E
1.2m=19.2E,23.5E,26E
1.2m=39E
0.8m=1W
VU+ SOLO SE
VU+SOLO
מנוי ל-DOLCE
TVR HD
Highway Star
הודעות: 855 הצטרף: 17 אוגוסט 2009, 00:57
שליחה
על ידי Highway Star » 06 יולי 2011, 20:30
אם עושים אקטיבציה לא בממיר מקורי כרטיס יעבוד על ממיר אחר?
Optibox Gekko HD
bogyman
שליחה
על ידי bogyman » 07 יולי 2011, 09:26
Highway Star @ 6/7/2011, 19:30 כתב:
כן
assem
שליחה
על ידי assem » 07 יולי 2011, 10:13
החדשות בפורומים מחו"ל מדברים על הכנסת השיתוף תוך מס' ימים (מחכים לקבלת ממירים כדי להתחיל לשתף), כמו שאמרו פה , נחכה ונראה.
hezibt12
הודעות: 1417 הצטרף: 05 אוקטובר 2005, 17:47
מיקום: כפר סבא
שליחה
על ידי hezibt12 » 08 יולי 2011, 19:59
זה יהיה אם פרסומות?
שליחה
על ידי gilad2211 » 08 יולי 2011, 23:08
לא נראה לי שזה יהיה עם פירסומות. גם משלמים דמי מנוי וגם מקבלים פירסומות? לא הגיוני למרות שבהמון ערוצים שמשלמים עליהם הם גם שמים פירסומות בשביל לשחוט את הלקוח.
naveh
הודעות: 283 הצטרף: 27 אוקטובר 2005, 17:57
שליחה
על ידי naveh » 10 יולי 2011, 13:06
יש פרסומות.
אין מנוי לחבילה. פשוט צריכים לקנות ממיר technosat HD שעלותו בערך 1200 שח ולאחר האקטיבציה החבילה עובדת.
VU+ UNO
Astra 23.5°E - Amos 4.0°W - Hotbird 13.0°E - Thor 1.0°W - Astra 4.8°E
Eutelsat 16.0°E - Astra 19.2°E - Eurobird9.0°E - Eutelsat 7.0°E - Hellas 39.0°E
vipersvcd
הודעות: 1442 הצטרף: 19 מרץ 2008, 10:05
שליחה
על ידי vipersvcd » 10 יולי 2011, 13:48
זה יפתח גם את אבו-דאבי ו OSN ?
hezibt12
מיקום: כפר סבא
שליחה
על ידי hezibt12 » 10 יולי 2011, 16:42
naveh @ 10/7/2011, 13:06 כתב:
יש פרסומות.
וואלה יופי,
גם לקנות את הממיר וגם לראות אם פרסומות >ניראה לי מוזר לא
כרגע זה פתוח?
שליחה
על ידי gilad2211 » 10 יולי 2011, 17:07
יש פרסומות.
זה חוצפה אבל לא משנה. האקטיבציה הזו היא לזמן מוגבל? אם כן אז לכמה?
naveh
שליחה
על ידי naveh » 10 יולי 2011, 17:56
gilad2211 @ 10/7/2011, 16:07 כתב:
זה לא מוגבל כי החבילה "" "בחינם" "" .
הערבים צריכים ממיר של OSN מעליו ממיר ל MBC ועוד מעט בטח יוסיפו מעל ממיר ל ART.
גם הערבים כועסים, זה בסדר.
VU+ UNO
שליחה
על ידי gilad2211 » 10 יולי 2011, 19:17
naveh @ 10/7/2011, 17:56 כתב:
הערבים יכולים לשנות את זה. כבר ראינו מה קרה במצריים
