מקלט חדש לשיתוף
Overview - EV-8000S
The brand new ELANVISION EV-8000S is the most complete DVB-S Two-Tuner PVR Settop Box that has ever been released. It is by far the most powerful solution compared to any of its competitors, using a LINUX operating system, an alphanumeric VF-Display,and providing two DVB-S tuners, a USB Host controller and a 100Base-T Ethernet socket, thus offering virtually unlimited capabilities. Using a IBM PowerPC CPU and the provided API for Plug-In developers, interested users may develop their own Plug-Ins for the EV-8000S and thus explore what this solution is really capable of, in addition to its already amazing basic features, which are already top class and unparalleled.
Back to Top
Main Features - EV-8000S
2-Tuner PVR-ready Digital Satellite Receiver
Max. Hard Drive capacity up to 144 Petabytes
TimeShift-Recording (Automatic/Manual)
Record two services at the same time while time-shifting a third service
Timer-Recordings programmable directly from the (super-fast) EPG
PiP (Picture-in-Picture)
True Color OSD (On-Screen-Display)
Alphanumeric Vacuum Fluorescent Display
USB Host Controller Connect mass storage devices or even digital cameras from various vendors (i.e. Canon, Sony, Nikon, Fuji, Olympus, Samsung, Casio etc.)
10/100 Mbps TCP/IP Ethernet (LAN) Connection Seamless integration in your home network.
JPEG-Mode: Picture Viewer and Slide Show generator
Music-Player and various other plug-in applications available
Memory for up to 3500 TV and 1500 Radio services
Service and favorite lists fully editable directly with the Remote control unit or by PC
DVB and Teletext subtitles available, Teletext Page memory up to 1000 pages
S/PDIF Output for digital audio or Dolby AC3 bit stream output
Recorded files are fully editable
2x Common Interface, optional separately available Smartcard Reader Kit
Powerful combination of IBM PowerPC hardware and firmware based on Linux O/S
Back to Top
Technical Specifications - EV-8000S
Tuner and Channel Decoder
Connection
75IEC 169-24, Female 2 LNB Input, 2 LNB Output
Frequency
950~2150 MHz
Output signal level
-65 ~ -25 dBm
DiSEqC Level
1.0/ 1.2/ USALS
MPEG Transport Stream A/V Decoder
Transport Stream
ISO/IEC 13818-1 MPEG-2
MPEG Profile Level
MPEG-2 MP@ML
Aspect Ratio
4:3, 16:9, Pan & Scan, LetterBox, Auto
Resolution
720x576 (PAL), 720x480 (NTSC)
Audio Decoder
MPEG-1 Layer 1, 2 & 3
A/V and Data In/Out
TV-SCART
Video CVBS/ S-VIDEO/ RGB/ YPbPr Output
Audio L/R Output
VCR-SCART
Video CVBS Output
Audio L/R Output
Video CVBS/ YC / RGB Input Bypass
Audio L/R Bypass
RCA (Cinch) A/V
Video CVBS Output
Audio L/R Output
S/PDIF
Optical Digital Audio / Dolby AC-3 Bitstream Output
RS-232C
Data Rate 115200 bps
9 pin D-Sub Female
USB
USB 1.1 Host Controller
Ethernet
10/100 Mbps Ethernet Controller
Main System
Main CPU
IBM Power PC
Memory
Flash-ROM 8MB
DRAM 48MB
EEPROM 2KB
Hard Drive
Ready for Standard IDE 3.5 P-ATA, max. 144 Petabytes
Front Danel Display
Alphanumeric VFD (Vacuum Fluorescent Display)
Power Supply
Input Voltage
90~250V AC, 50/60 Hz
Type
SMPS
Physical Specifications
Dimensions
380 x 70 x 300 (mm)
http://elanvision.com/products.html#Anchor_resource1
Back to Top
Back to Top
Connection
Frequency
950~2150 MHz
Output signal level
-65 ~ -25 dBm
DiSEqC Level
1.0/ 1.2/ USALS
Transport Stream
MPEG Profile Level
MPEG-2 MP@ML
Aspect Ratio
Resolution
Audio Decoder
A/V and Data In/Out
TV-SCART
Audio L/R Output
VCR-SCART
Video CVBS Output
Audio L/R Output
Audio L/R Bypass
RCA (Cinch) A/V
Video CVBS Output
Audio L/R Output
S/PDIF
RS-232C
9 pin D-Sub Female
USB
Ethernet
Main System
Main CPU
IBM Power PC
Memory
Flash-ROM 8MB
DRAM 48MB
EEPROM 2KB
Hard Drive
Front Danel Display
Power Supply
Input Voltage
Type
SMPS
Dimensions
380 x 70 x 300 (mm)
- amir777
- הודעות: 940
- הצטרף: 16 ספטמבר 2005, 20:55
sathack
- הודעות: 1729
- הצטרף: 23 דצמבר 2003, 11:46
- מיקום: קרית מוצקין
sathack
- הודעות: 1729
- Zacky
- הודעות: 4354
- הצטרף: 22 דצמבר 2003, 20:05
basselmk
- הודעות: 13
- הצטרף: 07 אוקטובר 2004, 07:28
- מיקום: חיפה
israel15
israel15 לגבי מקלטי VM 8000 היה ראשון אפשרות חיבור ETERNET אחרי הדרים
אשר הגיעה מקוראה
ELANVISION אותו מקלט רק מיוצר בגרמניה
המחיר מאווד סביר למקלט כזה
לגבי ניסים משווק מקלטי EV 8000 במחיר סיביר עבור לקוחות למתקינים שונים
כמה תמונות על המקלט זה
בקרוב RELOOK 500 דגם חדש
אשר הגיעה מקוראה
- פרופלור
- הודעות: 4494
- הצטרף: 27 דצמבר 2004, 22:43
שוב אתם מביאים לי מקלט גרמני אבל אני מחפש משהו לא גרמני. מתוך חילופי דברים כאן לא הבנתי כלום האם ישנו מקלט קוריאני שמתאים לשיתוף. נזרקו כאן שמות המקלטים עם אפשרות חיבור ל- ETERNET האם משהו מהם מתאים לשיתוף? מעבר שאלתי כאן וקבלתי תשובה שלמעשה אין חוץ מ- DREAM וכרטיס SKY שניהם גרמניים. מודה למשיב. פרופלור
israel15
israel15
- הודעות: 30820
ישראל15, אני דואג לחברי הפורום שלא יכתבו עליהם דברים אישיים בניגוד לרצונם בדיוק כמו שאם מישהו יכתוב עליך דברים אישיים ללא הסכתמך אני אדאג להגן על האינטרסים שלך.
אני דיברתי עם m8m8 ממש לפני שמחקתי את דבריך והוא היה ממש פגוע מהדברים שכתבת ורצה שאמחק אותם.
נראה לי שאתה חושב שאם אדם מדבר איתך במסנגר או בטלפון ועוזר לך אז זה נותן לך זכות לכתוב עליו מה שמתחשק לך. אתה טועה. ללא אישור מפורש אין לך שום זכות לכתוב דברים אישיים על אף אחד בפורום פתוח.
הסליחה שלך צריכה להיות מכוונת אל m8m8 ולא אלי. הוא זה שפגעת בפרטיות שלו.
israel15
