Evocamd-Next Level version 2.00
- הודעות: 30808
- Has thanked: 9 פעמים
As evocamd now uses enigma specific socket messages, it was not possible to keep all machines in one binary.
From now on you will find some extra directories for binaries.
- dreambox_7025
- dreambox_ppc
- dragon
- relook
- dbox
New is the mipsel(7025) and ppc Dream binaries. You will now be able to watch one channel and record more
channels at the same time, and this without any changes in enigma source. No patch is needed for this.
On 7025 you will be able, with two tuners to record two channels and watch a third at the same time(dunno any CI that can do this )
On 7020 or 7000 you must enable in CI menu "can handle two services", you are then able to record one
channel and watch another at the same time, but note this is only possible on the same Transponder.
Camd3 client old proto is enabled again, so you can use it to talk with dukat or freezers servers around
Radegast client is enabled too, and tested.
Important!
Few words about multichannel, please keep in mind that not all cards suport too many requests same time, and please
if you use some Spider Network dont use it just for fun..use it just if needed as you will make higher traffic in net.
- dreambox_7025
- dreambox_ppc
- dragon
- relook
- dbox
Important!
- הודעות: 690
- הצטרף: 07 אוגוסט 2004, 17:47
- הודעות: 95
- הצטרף: 26 פברואר 2004, 07:55
- הודעות: 690
