mpeg 4 on prob dvb
שלבי התקנה כדי לצפות בפורמט MPEG-4
Steps to enable ProgDVB to receive HD broadcasting
1. Register all filters (*.ax files) using the command regsvr32 (for example, regsvr32 elaudec.ax)
2. Replace ProgDVBEngine.dll and ProgDVB.exe in the folder where ProgDVB is installed (by default it is C:\ProgDVB)
3. Copy the file tv.elecardAVC.xgr into C:\ProgDVB\FilterGraphs
4. Launch ProgDVB with the switch /tsmode
5. In ProgDVB connect the required graph: Settings-> Audio and video -> DirectShow -> TV Channels (select ElecardAVC),
select video renderer "by graph file"
6. Set up the program to receive a stream from Satellite Yamal 202 (in the ProgDVB list it is called Yamal 102)
Parameters:
Band: C-Band, left polarization
Transponder frequency: 3834000 K Hz
Symbol rate: 5425
7. Scan the transponder and select the channel (there is the only channel there).
Parameters:
Symbol rate: 5425
				assyt
 - הודעות: 40
 - הצטרף: 05 אפריל 2005, 11:23
 - מיקום: צפון
