pli image
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
The Flubber suite includes the following components:
2.6.9 kernel
2.6.9-dream-s8 kernel for the 7020
1.09 enigma (28-07-2006)
1.1.0 Head.ko
Front Processor version 1.06 for DM7000
Front Processor version 1.01 for DM7020
Squashfs 2.2-r2 with LZMA-compression for the dm5xx(x) and dm7000 boxes
Tuxtxt v1.98
Web Interface: 5.9.7-Expert - PLi edition
New in Flubber
MultiEPG has been updated to show a Picture in Graphic (PiG). This works for the dm7000 and dm7020 boxes. Unfortunately, due to hardware limitations, the dm5xx(x) boxes do not support PIG. Instead a placeholder will be shown instead. Flubber includes a special fix to also make this work for NTSC systems. The event genre is now also shown in the event description window (when available). Now in Flubber you can even use '<' and '>' to quickly jump backward / forward in time.
Flubber supports reading 32-bit (!) png images as skin images and writing 32-bit osdshots. The Enigma internal picture viewer now works in 32-bit colormode for dm7000 and dm7020, and 8-bit mode for dm5xx(x), which now at least allows to show images on dm5xx(x). Scaling, resizing, and pan images has also been implemented. See the technotes pages.
The Skin/OSD on dm7000 and dm7020 still defaults to 8-bit colormode, but a 32-bit version of the default skin (MediaPLi) is available, to enjoy the pleasure of a full 32-bit OSD. The reason for not setting the default to 32-bit, is that several boxes show occasional green glitches in the mpeg stream, while they are in 32-bit mode. As it seems due to hardware/driver limits. We suggest you try for yourself how your 70x0 box works with 32-bit, so it is up to you to use either the 8-bit or 32-bit version of our revolutionary MediaPLi skin. Note that we have hugely improved the 8-bit possibilities for skins, by parsing palette colors from the skin images. So owners of 8-bit boxes are certainly not left behind.
http://pli.dreamvcr.com/dm500/pli-Fl...60801-1466.zip
http://pli.dreamvcr.com/dm7020/pli-F...60801-1466.zip
http://pli.dreamvcr.com/dm7000/pli-F...60801-1466.zip
http://pli.dreamvcr.com/dm56x0/pli-F...60801-1466.zip
pakwan
הודעות: 2268
הצטרף: 01 אפריל 2005, 11:12
מיקום: נתב"ג
שליחה על ידי pakwan »
הMulti EPG נשמע מעניין, רק שלא הבנתי מה ה Picture in Graphic אמור להיות
הודעות: 30816
יש גם מולטיEPG פלאגאין לג'מיני.
הבעיה שאלו דברים שמתאימים לדרימים הגדולים.
