סריקת ערוצי dvb-c
ramimz
הודעות: 605
הצטרף: 10 אוקטובר 2007, 23:00
Re: סריקת ערוצי dvb-c
שליחה על ידי ramimz »
היי ישראל.
את כל אלה אני סורק..... יכול להיות שיש עוד שחסרים לי ?
- <sat flags="0" name="DVB-C Cable" position="500">
<transponder fec_inner="5" frequency="1102000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1306000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1346000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1354000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1434000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1410000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1442000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1458000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1466000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1474000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1482000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1490000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1498000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1522000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1530000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1538000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1546000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1554000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1562000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1570000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1578000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1586000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1594000" inversion="0" modulation="5" polarization="0" symbol_rate="06510000" system="0" />
<transponder fec_inner="5" frequency="1602000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1602000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1610000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1610000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1618000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1626000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1626000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1634000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1634000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1642000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1650000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1650000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="4" frequency="1802000" inversion="0" modulation="5" polarization="0" symbol_rate="05360000" system="0" />
<transponder fec_inner="5" frequency="1000000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
</sat>
DM800se Clone - Amazing unit
צלחת 1מ' 5E, 4W, 7W
ramimz
הודעות: 605
ורק בשמונה ערוצים הוא מוצא לי ערוצים.
קוד: בחירת הכל
  </sat>
צלחת 1מ' 5E, 4W, 7W
י א כתב:ערוץ MTV Series HD תדר 610
קוד: בחירת הכל
1_0_19_12D_C_DE_FFFF0000_0_0_0
אין EPG
תודה ישראל.
ביס קוראים לזה רק MTV.
אתם בטוחים שזה אותו אחד?
מישהו יודע איפה יש EPG בעברית לערוצים
PENTHOUSE ו- BEARLY LEGAL?
Pazzini
הודעות: 284
הצטרף: 12 אוקטובר 2010, 19:43
שליחה על ידי Pazzini »
דיפ בשום דרך אני לא מצליח להעלות את הערוצים ניסיתי כל מה שאמרת.. אולי תעלה לי את קובץ EPG.DAT שלך תגיד לי איפה להשים אותו ותצרף אליו את קובץ הSETTINGS שאני הראה שאין לי בעיה כלשהי בממיר
תודה רבה
אחרי עבודה מרובה, הצלחתי, למרות החסימה של הוט, לסדר שיהיה לנו EPG גורף לכמעט כל הערוצים, חוץ מאיזה 5 ערוצים ברוסית.
נשאר לי רק לסדר את ה-SERVICE REF וסיימנו.
אני מוסיף גם EPG להרבה ערוצים של יס וכשאגמור את זה גם שם יהיה יותר מלא.
ramimz
הודעות: 605
מישהו יכול לעזור לגבי תדרים ?
על אילו תדרים יושבים ערוץ 10, ערוץ 2, היסטוריה ?
צלחת 1מ' 5E, 4W, 7W
מיכאלוש
הודעות: 199
הצטרף: 14 אפריל 2013, 22:11
שליחה על ידי מיכאלוש »
דיד ישפיץ
צריך להודות לחברים satbeginner, deepspace מיכאלוש ועוד שכולם ביחד הביאו לתנופה למציאת פתרון לנושא הזה.
ramimz
הודעות: 605
תודה רבה לכולם |כן|
אבל יש רק בעיה אחת.... אתם רצים רצים רצים
ושוכחים שלפעמים יש כאלה שנתקעים קצת מאחור.
שאלתי כמה שאלות בדף האחרון... ועושה רושם שהן ממש שקופות
אף אחד לא מגיב, למרות שכולם יודעים את התשובות.
מעט לא מכובד.
צלחת 1מ' 5E, 4W, 7W
מיכאלוש
הודעות: 199
רמי יכול להיות שהבעיה הממיר שלך
ramimz
הודעות: 605
וזה למה ?
אין כאן אף אחד שעובד עם ממיר כמו שלי ?
דרים 800HD סיני עם שלושה טיונרים.
אימיג' של OpenPLi-2.1-HD aguda
מישהו בנוסף על Deep יכול לצרף כאן את הקובץ satellites.xml שלו ?
על איזה אימיג' הפלאג הזה עובד הכי טוב ?
באילו תדרים נמצאים ערוץ 2, 10, והיסטוריה ?
יש עוד הרבה שאלות, אבל צריך להתחיל מאיפה שהוא
צלחת 1מ' 5E, 4W, 7W
הבעיה שלך היא סריקת הערוצים או ה epg?
ramimz
הודעות: 605
היי ישראל.
זה גם וגם...... אבל אנסה לפתור בעיה בעיה.
קודם כל מסקרן למה בסריקה נמצאו רק 215 ערוצים.
Deepspace העלה את הקובץ שלו לכאן, ובסריקה שהוא ביצע נמצאו למעלה מ- 800 ערוצים.
אני עם אותו הקובץ הצלחתי למצוא 215 ערוצים.
התדרים שאצלי בשימוש הם:
410
458
466
474
578
586
602
610
הבנתי שערוץ 10 נמצא על תדר 562
וערוץ 2 על תדר 586.
האם גם זה נתון על פי אזור, או שאצל כולם זה מופיע באותם תדרים ?
צלחת 1מ' 5E, 4W, 7W
תשים פה את הקובץ שלך.
אולי כשערכת את הטקסט נפלו טעויות.
ערוץ 2 ו-10 רשמתי בהערות בתוך הקובץ איזה תדר הם.
ramimz
הודעות: 605
קוד: בחירת הכל
	</sat>
צלחת 1מ' 5E, 4W, 7W
SR צריך להיות ככה 6890000
MODULATION שנה ל-0
סרוק מחדש
ramimz
הודעות: 605
משנה ..... אבדוק ואעדכן.
צלחת 1מ' 5E, 4W, 7W
ramimz
הודעות: 605
לא עזר :(
התפלגות הערוצים:
תדר 410 נמצאו 7 ערוצים.
תדר 458 נמצאו 38 ערוצים.
תדר 466 נמצאו 38 ערוצים.
תדר 474 נמצאו 22 ערוצים.
תדר 578 נמצאו 31 ערוצים.
תדר 586 נמצאו 30 ערוצים.
תדר 602 נמצאו 23 ערוצים.
תדר 610 נמצאו 26 ערוצים.
סה"כ 215 ערוצים :(
צלחת 1מ' 5E, 4W, 7W
ramimz
הודעות: 605
קוד: בחירת הכל
  <transponder fec_inner="5" frequency="1102000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1306000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1346000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1354000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1410000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1434000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1442000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1458000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1466000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1474000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1482000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1490000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1498000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1530000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1538000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1546000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1554000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1562000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1570000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1578000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1586000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1602000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1610000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1618000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1626000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1634000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1642000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  <transponder fec_inner="5" frequency="1650000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
  </sat>
צלחת 1מ' 5E, 4W, 7W
נסה לשים גם את FEC על 0.
אתה יכול גם לנסות לשים את INVERSION על 1 (אני זוכר שפעם זה פתר לי משהו).
נערך לאחרונה על ידי deepspace ב 12 ינואר 2016, 21:19, נערך פעם 1 בסך הכל.
