טכנית אפשר לחבר עוד צלחת לכבל של יס שניכנס לבית ?
elibar
הודעות: 401
הצטרף: 09 מרץ 2007, 13:47
שליחה על ידי elibar »
מצאתי את ההסבר הזה עבור תפקוד מולטיסוויטש.
אני בטוח שזה יענה להרבה שאלות.
אבל עדיין לא הבנתי, אם משתמשים במולטיסוויטש, האם ניתן גם לחבר דייסק לפני הסוויטש (לריבוי LNB)
To better understand how a multiswitch works with a satellite antenna, lets get an understanding of how the two work together.
The LNB on your satellite dish is capable of tuning to a satellite transponder that is broadcasting in either left-hand or right-hand circular polarity. A technical explanation of this is pretty involved and for the purposes of this explanation you'll just take our word for it. When you tune to a channel on your receiver, the receiver sends a switching signal back up the coax cable to the LNB in the form of a 14-volt or 18-volt DC voltage level to select the correct polarity for the transponder you have requested. This is why you cannot use a splitter for adding additional DSS receivers. If you do, the LNB gets a conflicting set of commands from the two sat receivers if they both try to access transponders of differing polarity. As a result, you can get a signal on one receiver while not the other if different transponders have been selected by each. You can set up two DSS receivers on a dish with a dual LNB using a dedicated line for each receiver. If you want to set up more than two receivers then you need a multiswitch.
A multiswitch is basically a box that contains splitters and A/B switches. The outputs of each LNB are connected to the A and B inputs of the multiswitch. In this configuration, one LNB is dedicated to left-hand polarity transponders and the other LNB is set up for right-hand polarity. The inputs to the multi-switch from the LNBs are split for either 4 or 8 outputs each (more if a larger multiswitch is desired). These split outputs are paired and connected to a series of A/B switches such that one side of the switch sees input A and the other side sees input B.
The outputs of the multiswitch are routed to each receiver you have in your household. When you tune to a channel, instead of the LNB being switched to the correct polarity, the 14-volt or 18-volt signal selects either transponder A or B by toggling the A/B switch. The LNBs are no longer switched when you change channels. Instead, the switching occurs inside the multiswitch (hence the name) and the correct polarity is selected for the desired channel/transponder.
Note that there are two different types of multiswitches available - passive (unpowered) and active (powered). If you have cable runs longer than 100 feet for any receiver, a powered multi-switch is highly recommended. The long run can degrade the voltage output from the receiver and the multiswitch may not work properly if the voltage drop is too great. A powered multiswitch detects the difference in the voltage levels and compensates for i
אלי,
יש כל מיני דגמים של מולטיסוויטש, והרעיון בשימוש במולטיסוויטש הוא כתחליף למס' דייסקים ,קומביינרים ועוד.
לדוגמה: יש דגם של מולטי סוויטש שיודע לקבל 4 LNB, כאשר כל LNB הוא עם 4 כניסות (LNB "מרובע" ), ולהיות מחובר ל-4 ממירים שונים.
במצב כזה כל החיווט שיוצא מה-LNB ים יחובר למולטיסוויטש, כלומר 16 כבלים.
ומהמולטיסוויטש יחוברו 4 כבלים ל-4 ממירים שונים.
בחיבור כזה אין מקום לשלב דייסיק חיצוני, ואינני בטוח אם המולטיסוויטש ידע "לחיות" איתו בשלום...
לסיכום: שימוש במולטיסווישט כזה "חוסך" 4 דייסקים , כלומר 4 דייסקים במארז אחד......
כמובן שאין כאן אלמנט של חיסכון, היות ומולטיסוויטש כזה עולה מעל 100 יורו, בעוד ש-4 דייסקים עולים 100 ש"ח.
בהמשך למאמר שפרסמת לעיל, יש דגמים של מולטיסוויטש שיודעים לבצע הפרדה בין V/H בשני תחומי התדרים, ובמצב כזה ניתן לחבר ליציאה כזאת מס' רב של ממירים, היות וכפי שציינתי התחומים מופרדים ולא תהיה התנגשות.
ישראל
יש גם מולטיסוויץ שמאפשרים לחבר 16 ממירים ואפשר גם לשרשר עוד מולטיסוויץ ולהכפיל את כמות הממירים.
אפשר אפילו לחבר 100 ממירים בבניין אחד
shachar
הודעות: 373
הצטרף: 10 פברואר 2005, 23:34
שליחה על ידי shachar »
איך מגדירים את הלווינים בממיר במקרה של שימוש במולטיסוויץ'?
satcard
הודעות: 1368
הצטרף: 08 מרץ 2004, 12:01
מיקום: מיחשוב
שליחה על ידי satcard »
בקיצור יס משתמשים במולטיסוייץ
ואני עדיף לי לעשות נקודות חדשותבכל חדר לצלחת הפרטית מאשר מולטיסייץ הבעיה ש5 נקודות חדשות יעלו יות רממולטיסייץ.
אבי כהן
מגנטים גימיקים וצילום ארועים
טלפון 054-8066162
marx04
הודעות: 374
הצטרף: 17 יולי 2007, 20:13
שליחה על ידי marx04 »
שלום לכולם,
תודה רבה על הדיון המעניין. נראה לי שסוף כל סוף הבנתי כיצד יס מצליחים לשים הרבה ממירים על LNB עם יציאה אחת בלבד.
אם הבנתי נכון, יס יכולים לעשות זאת טכנית, משום שכל השידורים של יס משודרים דרך לווין אחד בלבד (עמוס), ועל כן די ב-LNB אחד כדי לקלוט אותם.
מאחר שכפי שב-BOAZMA הסביר, כל השידורים של יס הם באותו תחום תדר (הנמוך - בתחום של 10.7 עד 11.7GHz) והם בקיטב זהה (רק Vertical), אז כאשר הצרכנים השונים שמחוברים לאותה צלחת מעבירים תחנות בממירים שלהם, הממירים השונים המחוברים לאותה צלחת תמיד שולחים מתח בעוצמה זהה ל-LNB (של 14 וולט, כי זהו המתח הנשלח כדי להגיד ל-LNB להחליף תחנות בקיטוב אנכי Vertical). כמו כן, מכיון שכל השידורים הם בתדר נמוך, אף ממיר לא צריך לשלוח אות בתדר של של 22KHz (תדר שהממיר שולח ל-LNB רק כאשר הוא "מבקש" להחליף ערוץ בתדר גבוה, כלומר בתחום של 11.7 עד 12.75GHz).
הממיר מחובר לקופסת חיבור, שמגבירה את האות הנשלח מה-LNB לכבל ומפצלת את הכבל היחיד של ה-LNB למספר כבלים כמספר הממירים המחוברים. כמו כן,בקופסא זו מותקן DC BLOCK, כדי למנוע מהמתח שכל ממיר מעביר ל-LNB להגיע לממירים האחרים שמחוברים לאותו LNB.
לפיכך יס כלל אינם צריכים להשתמש ב-multiswitch - זה פשוט מיותר לצרכים שלהם.
לעומת זאת, כל אדם שהמערכת הלוויינית שלו כוללת יותר מ-LNB אחד (כלומר קולט יותר מלווין אחד), או שקולט שידורים בקיטובים שונים (אופקי ואנכי) או ביותר מתחום תדר אחד (נמוך וגבוה) - אינו יכול להשתמש בשיטה של יס. כדי שאדם כזה יוכל להשתמש ביותר מממיר אחד, הוא חייב לדאוג שבמערכת שלו ייצאו מכל LNB מספר כבלים שונים כמספר הממירים שהוא מתכוון לחבר למערכת (הכוונה לממירים שכל אחד מהם פועל עצמאית). זאת משום שבמערכת כזאת, העברה בין התחנות השונות עלולה לגרום לשליחה בו-זמנית של מתחים שונים מהממירים ל-LNB. אם כל הממירים יהיו מחוברים ל-LNB באותו כבל, הדבר "יבלבל" את ה-LNB ועלול לגרום לשריפתו. הבעיה נפתרת על ידי כך שמחברים כל ממיר בכבל נפרד ליציאה נפרדת ב-LNB (עם זה ה-LNB מסוגל להתמודד).
האם הבנתי נכון ?
בברכה,
אורי.
הפועל מרמורק אימפריה !
נכון מאד.
alvox
הודעות: 224
הצטרף: 18 מרץ 2006, 10:38
שליחה על ידי alvox »
למה לא מספיק שתי כניסות ב-LNB, אחת ל-V והשניה ל-H, ומולטיסויצ' ידעג להעביר סיגנל לממיר עפ"י קוטביות המבוקשת?
כי יש גם תחום גבוה ונמוך שנשלט ע"י 22KHZ.
alvox
הודעות: 224
מה זה גבוה ונמוך?
באותו דיאפסון KU?
תחום ה KU מחולק לשניים. עד 11700 ומ 11700.
LNB אוניברסלי יודע לעבור בין התחומים לפי פיקוד 22KHZ.
erezb997
הודעות: 361
הצטרף: 12 יולי 2006, 01:13
שליחה על ידי erezb997 »
תיקון קל להסבר היפה שנתן marx04:
במערכת של יס הממירים של המנויים לא שולחים שום מתח ל-LNB. את המתח הוא מקבל ישירות מספק
מתח שנמצא בארון תקשורת ומזין אותו ישירות ב-14 וולט. כך שגם אם כל הדיירים כיבו את הממירים
שלהם ה-LNB ממשיך לקבל מתח מהחשמל הראשי של הבניין. ההוכחה: ברגע שיש הפסקת חשמל בבניין
לא ניתן לצפות בשידורים של יס ולמה? כי ה-LNB לא מקבל מתח.
הדבר היחיד שעובר מהממירים של הדיירים ל-LNB זה הבקשות להחלפת ערוץ.
elibar
הודעות: 401
שאלה:
האם כל ספקי תוכן לוויני (כמו יס) בשאר העולם עובדים באותה צורה?
לחלוטין לא.
שים לב לפרוט התדרים של החבילות בלינגסאט, יש גם ב-V וגם ב-H.
תיקון קל לתיקון האחרון של erezb997:
זה נכון בבתים משותפים. בבתים פרטיים המתח מגיע מאחד הממירים והשאר עם DC BLOCKER
erezb997
הודעות: 361
תודה על התיקון לתיקון |כן|
בכיף
alvox
הודעות: 224
האם בכלל קיים מושג כזה "החלפת הערוץ ב-LNB"?
הממיר ב-YES לא מקבל את כול התחום?
זה לא מושג נכון.
ה LNB מעביר את כל התחום לממיר והטיונר בממיר יודע להתמקד על התדר המבוקש ומתוחו להציג את הערוץ המבוקש.
כשאני אומר "כל התחום" אז הכוונה לאחד מארבעת התחומים של KU BAND.
