מקלט חדש לשיתוף
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
מקלט חדש לשיתופים
Relook 400s
מיפרט טכני
specifications
CPU IBM’s PowerPC405
Speed 350 MIPS
Data/Instruction Cache 16KB/16KB
Tuner (Twin)
& Channel Input Connector 2 x IEC169-2 female
Loop through Connector 2 x IEC169-2 male
Frequency Range 950MHz to 2150MHz
Loop through Out Impedance 75 ohms nominal
LNB
Control Band selection 22 KHz tone
Switch DiSEqC 1.0,1.1,1.2, USALS
Polarization 13/18V (400mA Max/per each)
MPEG Transport Stream & A/V Decoding
Transport Stream ISO/IEC 13818-1 Specification
Aspect Ratio 4:3, 16:9 with pan vector
Video Resolution 720 x 576(PAL)
Audio Decoding MPEG-1 Audio Layer 1,2
Network Ethernet RJ-45 (10Base-T/100Base-TX)
Memory Flash Memory 8MB + (expandable and users option)
SDRAM 96MB
Conditional Access System
Common Interface 2 slots PCMCIA TYPE 2 / DVB CI standard
smartcard 2 slots
RF-Modulator
RF-Connect 750hm, IEC 169-2, Male/ Female
Output Frequency 470MHz to 860MHz
Output Channel CH 21-69
TV Standard PAL D/K, PAL B/G, PAL I
A/V & Data In/Out
TV SCART 1 x SCART
VCR SCART 1 x SCART
RCA Video x 1, Audio x 2
Data Interface 9 Pin D-Sub, RS232C,
Power Supply
Input Voltage AC90-240V, 50Hz/60Hz
Power Consumption 50W max.(Under 7W max. at stand-by mode)
Physical Specification
Size (W x H x D) 375mm x 60mm x 280mm
Weight About 3 .0kg
Advanced Features
Application and Expansion
LINUX O/S enables ultimate applications to fulfill the customer's need
Max.Two Channels Recording and One Prerecorded File Playback
Enjoy enhanced watching and recording of TV programs
Simultaneous Double Descrambling on Viaccess CAM
Watching 1 Viacess ch. while recording another Viacess ch. with only 1 Viacess CAM. Playback of prerecorded programs without Viacess CAM
Simultaneous Double Descrambling on 2 CI CAMs
Watching 1 scrambled ch. while recording another scrambled ch. by using 2 CAMs. Play back of prerecorded programs without CAMs.
Playback without CAMs
Playback on a prerecorded scrambled program without CAM
Almost Unlimited Channel Memory
10,000 channels
Variable HDD Size is Applicable
Production from 40GB up to 250GB or above
Enhanced Search Channel Option
Search by all satellite
Search by satellite/ network
Search by all TP scanning
Unlimited Trick Play
Unlimited trick play on any of Real Time Live Programs/ Recording Program/ Playback on Prerecorded Program
Smart EPG
Automatically updates Program Info. EPG shows by all Satellites/ Search programs by Genre on the EPG
Enhanced Recording Plan
Timer setting/ User friendly designed EPG
Enhanced Playback
Skipping commercials/ Edit prerecorded files on PC
USB Connection to PC
PC Editor via USB connection(USB 1.1 supported)/ Enhanced program utility
Ethernet port supported
<_<
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
תמונה 2
Zacky
הודעות: 4354
הצטרף: 22 דצמבר 2003, 20:05
שליחה על ידי Zacky »
המחיר שלו באירופה ממש בשמיים....450 יורו !
פרופלור
הודעות: 4494
הצטרף: 27 דצמבר 2004, 22:43
שליחה על ידי פרופלור »
יש לו מודל מוקדם יותר גם הוא מתחבר למחשב לצורכי שיתוף (ככה הבנתי מהסבר באתר) האם בדקתם אותו. הוא עולה הרבה פחות !!! מועדים לשמחה לכל חברי הפורום! מצ"ב לינק לאתר (אם מישהו מעונין בתרגום מרוסית אני יכול לתרגם)
http://www.sk-digitaltechnik.de/oxid.ph ... l/-/lang/0
