HDTV
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
שידורים בחדות גבוהה ב MPEG-4 באופן קבועה
Premiere-HD without spectator?
לפחות MPEG-4 SS2
אהיה אפשר לצפות בכרטיס לויני
על אסטרה
עדין לא נימסר על איזה משיב יעלו את השידורים בחדות גבוהה
26.10.05
-------------------------------------------------------------------------------- . Quotation: the start of the premiere-HD-offer on the 19 November could take place according to information from the SAT + CABLE extensively under
end end of the public.
On inquiry, the manufacturers indicated Pace and Philips on Thursday that first test patterns of the planned HD-boxes are available at the earliest beginning of December. Series models come accordingly first end of the year and/or beginning of the next year. The manufacturer Homecast indicated the first quarter 2006 as a delivery date. Humax not first of all wanted to express itself to the availability of the new HD-model. Also a premiere-speaker was not attainable on inquiry of the SAT + CABLES.
A Stolperstein on the way for high resolution television is obvious a central building block: the MPEG4-Decoder. . Premiere sends its three HD-programs in the compression procedure MPEG4/H.264 und der Modulationsnorm and the modulation standard DVB-S2 in the format 1080i. To be sure the decoder in sufficient number of pieces is available are, the costs however obviously very high and verhageln the manufacturers the planned margin.
Concerned of the Receiver-deficiency, also the private transmitters are ProSieben and Sat. 1, that with unencoded HDTVS-radiations also in MPEG4 on that 26th or 27 Octobers want to go on shipment, (SAT + CABLE reported). Because there is yet no DVB-S2-, the reception way remains locked coached-PC with software-decoder also over one
Rittberg
הודעות: 1178
הצטרף: 29 דצמבר 2003, 06:33
מיקום: Omer
שליחה על ידי Rittberg »
בינתים נתוני שידור לגבי Sat.1 HD / ProSieben HD - המתחילים ב 27 לחודש זה,
חבל :angry:
ASTRA 1E, 19,2° Ost
Transponder 102
Downlink-Frequenz : 12,441 GHz
Polarisation: vertikal
FEC: 9/10
DVB-S 2
Videoencoding: MPEG4 / AVC - 1080i/25 (25 Vollbilder/Sekunde)
Audioencoding: AC3 - Dolby Digital
Service Name: Sat.1 HD / ProSieben HD
Service Provider: ProSiebenSat1
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
פרמיאר החלה פורומו MPEG-4
Astra 1F (19.2E) - Premiere HD Promo (Germany) broadcasts in DVB-S2 Clear on 12441.00 MHz, pol.V SR:27500 FEC:5/6 SID:0 PID:0/.
Rittberg
הודעות: 1178
מיקום: Omer
Pro7/Sat1 משדרים כרגע ב - HiDef על - 16E, 11148V, 13020, 3/4
זליג
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
ניקלט מאיכות מדהימה
yoramro
הודעות: 1278
הצטרף: 04 ספטמבר 2004, 20:00
שליחה על ידי yoramro »
האם אני יכול להבין שכרטיס לוויני יכול לפענח גם DVB-S2 או ששידורי הנסיון משתמשים בשיטות יותר קונבנציונליות?
יורם
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
dvbs2 זה סטנדאט שונה משאר DVBS הנוככי
חומרה שונה HARDWARE כולל מעבד DECODING DVBS2
יש כבר כיום מקלטי לווין אב תיפוס PACE
בקרוב יותר פרטים על שיטה זו
yoramro
הודעות: 1278
האם שידורי הנסיון משודרים בינתיים ב DVB-S?
איזה Codec פותח אותם?
האם מקליטים את ה Stream וצופים יותר מאוחר ב Off-line או שיש דרך לצפיה ב Real-Time?
יורם
Rittberg
הודעות: 1178
מיקום: Omer
יורם,
השידורים על ה ASTRA 19.2E מבוצעים היום בשיטת שידור - DVB-S2 ובדחיסת MPEG4 h.264 .
היות ושאלת לגבי "איזה Codec פותח אותם" - אני מניח שאתה עובד עם מחשב, לצערי לא בנמצא היום חומרה, קרי כרטיס לויני אשר מסוגל לטפל ב - DVB-S2 .
בזמנו כאשר פרמיאר שידרו פורומו ב- MPEG4/ h.264 אולם בשיטת שידור - DVB-S , ע"י תוכנת MY THEATER הצלחתי להקליט את ה STREAM ורק לאחר מכן לנגן אותו.
המפתחים של תוכנת DVBVIEWER הצליחו ליצור KIT אשר מאפשר לראות שידור MPEG4/ h.264 בשיטת שידור - DVB-S ב - Real-Time אולם אתה זקוק למחשב הכי מעודכן ( האצת ה - h.264 מבוצעת בכרטיס המסך - כגון כרטיס המבוסס על הצ'יפ GeForce 7800 ).
זליג
עלי שביט
הודעות: 388
הצטרף: 22 פברואר 2004, 16:20
מיקום: ישראל
Been thanked: 4 פעמים
שליחה על ידי עלי שביט »
חנוכת השידורים נדחתה למחר
PREMIERE תתחיל ב 3 בנובמבר
אין סיכוי שתשודר באלומה רחבה -הם ישתמשו כמעט בטוח באלומות של מרכז אירופה
Rittberg
הודעות: 1178
מיקום: Omer
עלי שלום,
כתבתה - "אין סיכוי שתשודר באלומה רחבה -הם ישתמשו כמעט בטוח באלומות של מרכז אירופה"
מהמקורות שלך - האם יש להם מושג באיזה אלומה הם ישתמשו ? האם יש סיכוי שישתמשו באלומה של שידורי הנסיון שהיו על ה- 11914.5H ?
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
ניתוני SAT 1 HD
על W2-16 E
11148V, 13020, 3/4, id: prosieben test
resolution: 1920x1080
bitrate: 16.671.200
audio: 192 kbs, 48 khz
yoramro
הודעות: 1278
אינני רואה סיגנל בתדר המפורסם ב 16E הם הסיבה היא שכרטיס הלווין שלי לא מבין את שיטת האפנון החדשה ועל כן "לא רואה" אותה?
Rittberg
הודעות: 1178
מיקום: Omer
על ה 16E אין כרגע כלום, השידור היה בשעות היום.נקווה שיעלה שוב מחר.
השידור בשיטה הרגילה : DVB-S ו - MPEG2
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
פרמיאר ישודר 11914H
לפי טבלת אסטרה
yoramro
הודעות: 1278
השידור ב W2 זמין.
משודרת אופרת סבון ביחס 4:3
ביזבוז משווע של ביטים.....
יורם
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
3 בדצמבר מתוכנן מישחק
VfB Stuttgart against FC Bavaria Munich live
PREMIRE HD SPORT
16.30 לפי שעון ישראל
