מקלט חדש לשיתוף
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
Overview - EV-8000S
The brand new ELANVISION EV-8000S is the most complete DVB-S Two-Tuner PVR Settop Box that has ever been released. It is by far the most powerful solution compared to any of its competitors, using a LINUX operating system, an alphanumeric VF-Display,and providing two DVB-S tuners, a USB Host controller and a 100Base-T Ethernet socket, thus offering virtually unlimited capabilities. Using a IBM PowerPC CPU and the provided API for Plug-In developers, interested users may develop their own Plug-Ins for the EV-8000S and thus explore what this solution is really capable of, in addition to its already amazing basic features, which are already top class and unparalleled.
Back to Top
Main Features - EV-8000S
2-Tuner PVR-ready Digital Satellite Receiver
Max. Hard Drive capacity up to 144 Petabytes
Time–Shift-Recording (Automatic/Manual)
Record two services at the same time while time-shifting a third service
Timer-Recordings programmable directly from the (super-fast) EPG
PiP (Picture-in-Picture)
True Color OSD (On-Screen-Display)
Alphanumeric Vacuum Fluorescent Display
USB Host Controller – Connect mass storage devices or even digital cameras from various vendors (i.e. Canon, Sony, Nikon, Fuji, Olympus, Samsung, Casio etc.)
10/100 Mbps TCP/IP Ethernet (LAN) Connection – Seamless integration in your home network.
JPEG-Mode: Picture Viewer and Slide Show generator
Music-Player and various other plug-in applications available
Memory for up to 3500 TV and 1500 Radio services
Service and favorite lists fully editable directly with the Remote control unit or by PC
DVB and Teletext subtitles available, Teletext Page memory up to 1000 pages
S/PDIF Output for digital audio or Dolby AC–3 bit stream output
Recorded files are fully editable
2x Common Interface, optional separately available Smartcard Reader Kit
Powerful combination of IBM PowerPC hardware and firmware based on Linux O/S
Back to Top
Technical Specifications - EV-8000S
Tuner and Channel Decoder
Connection
75IEC 169-24, Female 2 LNB Input, 2 LNB Output
Frequency
950~2150 MHz
Output signal level
-65 ~ -25 dBm
DiSEqC Level
1.0/ 1.2/ USALS
MPEG Transport Stream A/V Decoder
Transport Stream
ISO/IEC 13818-1 MPEG-2
MPEG Profile Level
MPEG-2 MP@ML
Aspect Ratio
4:3, 16:9, Pan & Scan, LetterBox, Auto
Resolution
720x576 (PAL), 720x480 (NTSC)
Audio Decoder
MPEG-1 Layer 1, 2 & 3
A/V and Data In/Out
TV-SCART
Video CVBS/ S-VIDEO/ RGB/ YPbPr Output
Audio L/R Output
VCR-SCART
Video CVBS Output
Audio L/R Output
Video CVBS/ YC / RGB Input Bypass
Audio L/R Bypass
RCA (Cinch) A/V
Video CVBS Output
Audio L/R Output
S/PDIF
Optical Digital Audio / Dolby AC-3 Bitstream Output
RS-232C
Data Rate 115200 bps
9 pin D-Sub Female
USB
USB 1.1 Host Controller
Ethernet
10/100 Mbps Ethernet Controller
Main System
Main CPU
IBM Power PC
Memory
Flash-ROM 8MB
DRAM 48MB
EEPROM 2KB
Hard Drive
Ready for Standard IDE 3.5” P-ATA, max. 144 Petabytes
Front Danel Display
Alphanumeric VFD (Vacuum Fluorescent Display)
Power Supply
Input Voltage
90~250V AC, 50/60 Hz
Type
SMPS
Physical Specifications
Dimensions
380 x 70 x 300 (mm)
http://elanvision.com/products.html#Anchor_resource1
amir777
הודעות: 940
הצטרף: 16 ספטמבר 2005, 20:55
שליחה על ידי amir777 »
וכמה שווה התענוג?
DREAM 500S & 800HD PVR ; 4W ,7W, 7E, 13E, 16E , 19.2E ,25.5E , 26E
sathack
הודעות: 1729
הצטרף: 23 דצמבר 2003, 11:46
מיקום: קרית מוצקין
שליחה על ידי sathack »
539,95 EUR
בגרמניה (כולל מעמ מקומי של 16 אחוז)
sathack
הודעות: 1729
מיקום: קרית מוצקין
Zacky
הודעות: 4354
הצטרף: 22 דצמבר 2003, 20:05
שליחה על ידי Zacky »
539 יורו ? במחיר הזה אני יכול לרכוש דירה קטנה בקריות....
basselmk
הודעות: 13
הצטרף: 07 אוקטובר 2004, 07:28
מיקום: חיפה
שליחה על ידי basselmk »
אני מחכה לממיר עם תמיכת HD כי יש כבר ערוצים שמשדרים בHD
דרך אגב מחיר זה הוא סביר לממירים בקטגוריה זו
israel15
שליחה על ידי israel15 »
M8M8 ..עם אתה תמשיך עוד לפרסם כאן על כאלה מקלטים ..אנשים פה יצטרכו לקחת משכנתא..
ועם כבר מקלטים..אז למה אתה לא מעלה כאן תמונה של המקלט ..|dance|
חלק מהדברים נמחקו לאחר ברור עם m8m8
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
israel15 לגבי מקלטי VM 8000 היה ראשון אפשרות חיבור ETERNET אחרי הדרים
אשר הגיעה מקוראה
ELANVISION אותו מקלט רק מיוצר בגרמניה
המחיר מאווד סביר למקלט כזה
לגבי ניסים משווק מקלטי EV 8000 במחיר סיביר עבור לקוחות למתקינים שונים
כמה תמונות על המקלט זה
בקרוב RELOOK 500 דגם חדש
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
תמונה 2
פרופלור
הודעות: 4494
הצטרף: 27 דצמבר 2004, 22:43
שליחה על ידי פרופלור »
שוב אתם מביאים לי מקלט גרמני אבל אני מחפש משהו לא גרמני. מתוך חילופי דברים כאן לא הבנתי כלום האם ישנו מקלט קוריאני שמתאים לשיתוף. נזרקו כאן שמות המקלטים עם אפשרות חיבור ל- ETERNET האם משהו מהם מתאים לשיתוף? מעבר שאלתי כאן וקבלתי תשובה שלמעשה אין חוץ מ- DREAM וכרטיס SKY שניהם גרמניים. מודה למשיב. פרופלור
israel15
ZZZZZZZZZZZZZZZZZZZZZז
הכל נמחק לאחר ברור עם m8m8
ובכלל, אני חושב שאתה צריך לבקש רשות האדם לפרסם פה את אהבותיו ואת נסיעותיו ומטרתן.
israel15
הכול כמובן ברוח טובה ובאווירה נעימה..M8M8 ..בן אדם זהב..הלוואי ויהיו פה עוד אנשים כמוהו..
רוח טובה ואווירה נעימה... אישור לפרסם דברים אישיים יש?
לאחר ברור עם m8m8 נאמר לי שפרסום הדברים האישיים כאן לא היה באישורו ובניגוד מוחלט לרצונו. לכן הדברים נמחקו.
ישראל15 - אתה מוזהר מפרסום דברים אישיים על חבר פורום בעתיד.
israel15
ישראל..למה אתה מתעצבן ..הרי אתה יודע בעצמך כמה דורוון עזר לי ..אז בשביל זה לא צריך לאיים ..
אני מקודם דיברתי איתו והכול בסדר ..ועם אמרתי משהו לא בסדר אני מבקש סליחה .למרות שסליחות מבקשים רק ביום הכיפורים .אתה מכול דבר עושה סימפוזיון .קח את החיים את בקלות .חיים רק פעם אחת
ישראל15, אני דואג לחברי הפורום שלא יכתבו עליהם דברים אישיים בניגוד לרצונם בדיוק כמו שאם מישהו יכתוב עליך דברים אישיים ללא הסכתמך אני אדאג להגן על האינטרסים שלך.
אני דיברתי עם m8m8 ממש לפני שמחקתי את דבריך והוא היה ממש פגוע מהדברים שכתבת ורצה שאמחק אותם.
נראה לי שאתה חושב שאם אדם מדבר איתך במסנגר או בטלפון ועוזר לך אז זה נותן לך זכות לכתוב עליו מה שמתחשק לך. אתה טועה. ללא אישור מפורש אין לך שום זכות לכתוב דברים אישיים על אף אחד בפורום פתוח.
הסליחה שלך צריכה להיות מכוונת אל m8m8 ולא אלי. הוא זה שפגעת בפרטיות שלו.
israel15
אוקיי..אני כבר יטלפן אליו והכול יהיה בסדר..והכותרת מחר בעיתון תהיה ' ההר הוליד עכבר ' :D
