גמיני גירסה2.60
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
Gemini v2.60:
Technical Info:
* Enigma of: 19.12.2005
* GCC 3.4.4 Original CVS
* Web Interface: 5.8.1-Expert
* Busybox 1.01 ( <=7000 )
* Busybox 1.00 ( 7020 )
* Tuxtxt V1.94
Function Buttons:
* Blue - Blue Panel (BP)
* 2x Blue - BP -> Extras/Settings
* Yellow - Quick-Button (can be configured through the BP)
* Red - EPG List for the active channel
* 2x Red - EPG Style Menu
* Green - Subservices
Features:
* Own Addon-Server via Internet.
* AutoCam: Emus can be linked to Channel/Provider
* Cam-Settings: for example Renaming of Emus, Multichannel-Patch adjustable ( >=7000 )
* OSD: EMM- and ECM- Display activatable
* Possibillity to download and automatical install additional functions via Internet from the Gemini-Addon-Server
* System Info: Many exrta info about your Box (for example the Harddisk-Temperature or all other Enigma-Settings)
* Gemini-News are downloaded in the backround
* JPEGs can be rotated and the EXIF-Tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random - Function for MP3 and OGG
* Quick-Button-Menu: Many extra Functions for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if they use IDE or USB ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted Harddisk (only possible if no Harddisk is present in the box,the Mountpoint has to be "/mnt/usb" with a Minimum of 3GB)
* Extra Menu: Settings for many Extras like Inadyn, HTTPD, EPG-Cache, setting var to usb/hdd and many more
* Backup Function
* Dreamnetcast: with Shoutcast TOP(100)
* Backround pictures for Radio, MP3 and SCAN can be changed through Blue Panel.
* Custom Scripts can be started over Blue Panel
* Calender including Reminder (can be changed over .../gemini_cal.conf)
New:
* Convert MVI files from JPG, BMP, GIF or PNG Images in the menu "Backgroundpictures".
* The bootlogo of the 7020 can be changed in the menu.
* Two new setup options for music and pictures can be found in the root of the filemenu (BP->Extras/Settings->Root-entry).
* Create your own Satellites.xml.
* New Font and Libfribidi for arabian.
* EPG for Dishnetwork.
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD)).
* Alarm Clock with adjustable volume offset that plays your own WAV-files.
