.MULTIPROG UPDATER 02/2004 ------------------------------------------------------------------
This little however fine Update-tool includes the Bios-versions 2.1 and 3.2 for MULTIPROG 2001XL/XLD and
2003XXL/XXLD with 1- or 2-zeiligem display.
The function of the program explains type itself actually of even, nevertheless here a couple:
Before Programmierstart please the COM-Port, that Programmer-type, that select Bios-version and the amount of the display-lines. Hardware moderate a programming of the incorrect Bios is
blocked, is selected however the incorrect lines number of the display, can indicate the notice of the Programmers rubbish.
Do not forget to push the Programmierschalter of the Multiprog 2001XL/2003XXL before the Programmiervorgang to
the right. After programming push the switch again to the left, is otherwise no normal business of the
Programmers possible.
A "Sync-Error" means as a rule that either no Multiprog is connected, or is not the switch in right position.
With Bios 3.2, the new Twoprog version 3.x functions only. The old Twoprog versions can be used no longer. He who cannot afford the new Twoprog 3, (costs only 20 Euros), that can balance out
naturally again the Bios 2.1 and can use Twoprog 2. x.
http://www.twoprog3.de/?file=10&lang=ger
