כל התדרים על הוטבירד נכון לתאריך 1.5.06
adiga
הודעות: 690
הצטרף: 07 אוגוסט 2004, 17:47
שליחה על ידי adiga »
TRANSPONDER LIST (Digital Only)
Freq, Pol, Sr
10719, V, 27500 (77 channel)
10723, H, 29900 (26 channel)
10758, V, 27500 (23 channel)
10775, H, 28000 (68 channel)
10796, V, 27500 (19 channel)
10829, H, 3333 (2 channel)
10834, V, 27500 (19 channel)
10853, H, 27500 (10 channel)
10873, V, 27500 (58 channel)
10892, H, 27500 (48 channel)
10911, V, 27500 (30 channel)
10931, H, 27500 (27 channel)
10949, V, 27500 (18 channel)
10971, H, 27500 (35 channel)
10992, V, 27500 (15 channel)
11013, H, 27500 (33 channel)
11034, V, 27500 (21 channel)
11054, H, 27500 (22 channel)
11075, V, 27500 (11 channel)
11095, H, 28000 (22 channel)
11131, V, 5632 (5 channel)
11137, H, 27500 (17 channel)
11159, V, 27500 (8 channel)
11178, H, 27500 (17 channel)
11200, V, 27500 (32 channel)
11220, H, 27500 (20 channel)
11240, V, 27500 (27 channel)
11258, H, 24000 (12 channel)
11278, V, 27500 (82 channel)
11296, H, 27500 (18 channel)
11334, H, 27500 (12 channel)
11355, V, 27500 (35 channel)
11373, H, 27500 (11 channel)
11393, V, 27500 (11 channel)
11411, H, 27500 (1 channel)
11432, V, 27500 (13 channel)
11488, H, 27500 (21 channel)
11526, H, 27500 (5 channel)
11541, V, 27500 (21 channel)
11566, H, 27500 (10 channel)
11585, V, 27500 (21 channel)
11604, H, 27500 (25 channel)
11623, V, 27500 (22 channel)
11642, H, 27500 (12 channel)
11662, V, 27500 (29 channel)
11681, H, 27500 (16 channel)
11727, V, 27500 (20 channel)
11746, H, 27500 (14 channel)
11766, V, 27500 (10 channel)
11785, H, 27500 (29 channel)
11804, V, 27500 (18 channel)
11823, H, 27500 (26 channel)
11843, V, 27500 (25 channel)
11862, H, 27500 (24 channel)
11881, V, 27500 (15 channel)
11900, H, 27500 (17 channel)
11919, V, 27500 (5 channel)
11938, H, 27500 (18 channel)
11958, V, 27500 (12 channel)
11977, H, 27500 (19 channel)
11996, V, 27500 (30 channel)
12015, H, 27500 (21 channel)
12034, V, 27500 (19 channel)
12054, H, 27500 (15 channel)
12073, V, 27500 (24 channel)
12092, H, 27500 (28 channel)
12111, V, 27500 (36 channel)
12144, H, 3333 (1 channel)
12149, V, 27500 (25 channel)
12169, H, 27500 (35 channel)
12188, V, 27500 (24 channel)
12207, H, 27500 (30 channel)
12226, V, 27500 (88 channel)
12245, H, 27500 (16 channel)
12265, V, 27500 (4 channel)
12285, H, 27500 (49 channel)
12303, V, 27500 (26 channel)
12322, H, 27500 (12 channel)
12341, V, 27500 (18 channel)
12360, H, 27500 (19 channel)
12380, V, 27500 (28 channel)
12399, H, 27500 (31 channel)
12418, V, 27500 (14 channel)
12437, H, 27500 (21 channel)
12460, V, 27500 (25 channel)
12476, H, 27500 (54 channel)
12520, V, 27500 (28 channel)
12540, H, 27500 (31 channel)
12558, V, 27500 (94 channel)
12577, H, 27500 (26 channel)
12597, V, 27500 (51 channel)
12616, H, 27500 (20 channel)
12635, V, 27500 (20 channel)
12654, H, 27500 (31 channel)
12673, V, 27500 (6 channel)
12692, H, 27500 (15 channel)
12713, V, 27500 (11 channel)
12731, H, 27500 (20 channel)
[מנגן]
תמונהתמונה
[ART+ORBIT+SHOWTIME]
jan_p
הודעות: 134
הצטרף: 18 אוקטובר 2005, 18:29
שליחה על ידי jan_p »
וואלה תודה,:)
כמה מהם נקלטים בערץ בצלחת 1.2?
adiga
הודעות: 690
אם לא טועה את רובם יקלוט
תמונהתמונה
izikj
הודעות: 193
הצטרף: 25 אפריל 2005, 15:30
שליחה על ידי izikj »
תודה רבה
papassi
הודעות: 5
הצטרף: 14 נובמבר 2005, 18:20
שליחה על ידי papassi »
האם יש דרך לעדכן את התדרים דרך המחשב לדרים?
[עזרה]
adiga
הודעות: 690
כן דרך התוכנה dreamset
תמונהתמונה
papassi
הודעות: 5
אפשר הסבר קטן איך אני מושך את הרשימה מפה לתוך המכשיר הדרים.
האם העתקה והדבקה?
[עזרה]
האם יש פה תדרים שאינם מופיעים בלינגסאט?
adiga
הודעות: 690
לפי הבדיקה שלי
H, 3333 [2] CHANNEL 10829
V, 27500 [13] CHANNEL 11432
H, 3333 [2] CHANNEL 12144
זה מה שלא מצאתי בלינגסאט
[בירה]
תמונהתמונה
adiga
הודעות: 690
שלום papassi
אתה לא מושך מפה את הרשימה .
אתה פותיח את התוכנה , ובעזרת התוכנה אתה מושך את התחנות שיש לך בדרים והקובץ נקרא satellites.xml שנמצא ב var/etc בדרים , ושם אתה מוסיף את התדרים שיש פה , [רק מה שאתה רוצה] לרשימת הקובץ שמשכת מדרים , ואז אתה מעביר דרך התוכנה שוב את הקובץ , לאחר העידכון לתוך הדרים לספרית var/etc.
תבדוק פה בפורם אם יש הסבר להפעלת התוכנה , ואם אין זה ממש פשוט לא צריך ידע רב בשימוש.
ולגבי הקובץ ששמתי פה , זה אני עידכנתי דרך התוכנה ,ואתה יכול לעביר ישר לתוך הדרים דרך התוכנה , ואם יש תחנות שאת לא מעוניין אתה יכול למחוק גם דרך התוכנה .
בקיצור התוכנה בשביל עידכון והוספה והסרה של תחנות וחבילות.
אני מקווה שהסברתי טוב מקווה. ;)
[מנגן]
תמונהתמונה
התדר 10829 מופיע בלינגסאט בתדר 10830
התדר 12144 מופיע בלינגסאט בתדר 12145
התדר 11432 לא נקלט.
אין למעשה שום שינוי ממה שמופיע בלינגסאט.
adiga
הודעות: 690
נכון אתה צודק ישראל אני טעיתי. [אופס]
תמונהתמונה
לא נורא אל תקח ללב. מי שלא עושה לא טועה וכל הכבוד לך על התרומה.
adiga
הודעות: 690
בכלל אין שום בעיה :) , ולא לוקיח ללב :D , להיפך טוב תמיד שמישהו מתקן לדבר הנכון |כן|
שנית אני מאוד שמיח לתרום את הידע המעט מאוד שלי לפורם ולחברים בפורם |כן|
ושרק יהיה לנו בריאות ואושר[בירה]
[מנגן]
תמונהתמונה
תומר
הודעות: 1726
הצטרף: 01 מרץ 2004, 17:46
שליחה על ידי תומר »
כל התדרים נקלטים מלבד אלומת הסופר של סקיי איטליה .
