זה מה שמצאתי באחד מי הפורומים
Hello everybody
This is my contribution for a "new" TPS AES Key Updater!
Tested with MgCamd and works fine!
If you want to add the script to your script-panel in Gemini, change the Script name to TPSKeyUpdate_userscript(x).sh and add it to the Script directory..
(x) = a number (Remove the ( ) char)
If you want the Script to automaticly check for new keys every 10 min, add the "TPSKeyUpdate.sh" script to /var/bin
And add the "TPSCronjob.sh" to /tmp
Remember to run CHMOD 755 to both files!
Telnet to the Dreambox and execute the Script "TPSCronjob.sh"...
Howto:
- Telnet to the Dreambox
- Write username: root
- Write password: dreambox (This is default)
- On the prompt write: cd /tmp
- Write: sh TPSCronjob.sh
- The job is now added to your Cronjob, and will check for new keys every 10 min!
Remember to activate Cronjob in your Image, if it's not running already
History:
v1.0
- TPS Key Update to via file
- Create Cronjob for auto update every 10 min
V1.01
- Place Old TPS Key to AESlib.key
- fixed bug in Cronjob script
V1.10
- added TPS Key Update to SoftCam.Key
- added Cleanup via file (Remove multiple instance of same Keys)
V1.11
- added Cleanup SoftCam.Key (Remove multiple instance of same Keys)
Regards,
NeoLoop
נא ליבדוק
TPS
- edilit
- הודעות: 436
- הצטרף: 26 נובמבר 2005, 14:00
