Joker CAM v1.17 FINAL
© MASARE TEAM
© SPONSORED BY NABILOSAT
* Some CAID Fix and rearregement
* K3 Implement
* XXX View Ready (you may not need this upgrade for only XXX)
ABOUT THIS VERSION
VER 1.17 FINAL for CAS 2 or 3
Viaccess 1-2 (TPS VIA 2.6 Implement)
Seca 1-2
Irdeto 1-2
Betacrypt tunneled Nagra 2
Cryptoworks (Version Bios 5)
Shl FullX Card (Now XXX View)
CA in menu:
-ALL
-Via
-Shl
-Shle
-Sec
-IrdA
-IrdB
-IrdC
-BetA
-BetB
-BetC
-Cw
XXX Support Activation/Deactivation
1-Enter Module Menu's at CAM CI
2-Choose "Status"
3-Enter 4 digit Parental Pin Code (then confirm same code second time)
4-Lock or Unlock XXX Channel emulation cam
You can see expiration date of XXX channel (till 2010)
XXX View Ready
Enjoy it !
MASARE TEAM
Martos, Saoud007, Renber
mr1200s, UltraVox, Gimesca, Reversi
and kamilz++
Greetings to
Alraqi, condor-70, coMMas
All NabiloSat Staff
All Masters of DVB Staff
						גירסה לגוקר
				DJ
 - הודעות: 732
 - הצטרף: 23 ספטמבר 2004, 18:08
 - מיקום: תל אביב
שידורים מתחילים 20.8
The transmitter Sex View XXX was already locked some days ago. It is already coded sent. The Blue Zeta Cam decodes the signal, but only a black fixed image is sent. Up-to-date Sex View XXX sends fixed image only with 0.3 Mbit, like the many channels. Only a black fixed image is sent thus up to now. The modules function perfectly, blos the this only the black fixed image decode. Who does not believe it, which one is to draw CI the module out, now the message should appear this channel is coded . This message is different depending upon Receiver. But if the module is in the Receiver, then this message should not appear. Possibly are nevertheless only to 20.08.2006 loosely. That was also first admitted date.
