GEMINI3.10
קבצים ולינקים המיועדים ל 7020 ו 7020HD בלבד
edilit
הודעות: 436
הצטרף: 26 נובמבר 2005, 14:00
שליחה על ידי edilit »
Gemini v3.10:
Technical Infos:
* Enigma of: 22.08.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.7-Expert
* Busybox 1.01
* Tuxtxt V1.98
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming, multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Download and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma settings)
* Gemini news loaded in background
* JPEGs can be rotated and the EXIF tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB (>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working without internal hard drive, mountpoint set to "var/mnt/hdd" and at least 3GB disk space)
* Extra menu: Settings for many features like Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many more
* Backup function
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can be changed via Blue Panel
* Calender including reminder (can be changed via
.../calendar.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created in the filemenu
(BP->Extras/Settings->Root-Entry)
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable
playing your own WAV-files.
* Display of current channel stream rates ( >=7000)
* cifs-1.42b
* Multisocket second camd socket (cam1.socket) switchable.
* Register an own addon server( useraddon.xml)
New:
* Provider, Frequency, symbol rate and FEC displayed on infobar (dependent on skin)
* Picon integrated in Gemini (the PNG file must have the same name as the channel) -> Installation of Picicons via Blue Panel
* True automount, examples in var/etc/automount.conf. Devices get mounted automatically and also erased if they are not in use for longer than 2 minutes
(only working if the kernel of Gemini 3.1 is in use)
* Installation of addons via browser
Fix:
* Dreamnetcast revised
* Multisocket support for more camd's
* attend cvs
Interfaces WebIF:
h**p://127.0.0.1/cgi-bin/GeminiInfo
h**p://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
h**p://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
h**p://127.0.0.1/cgi-bin/InitCam
h**p://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background.
Thanks a lot and have fun
Your Gemini-Team
http://dream-zone.info/forum/showthread ... #post11846
הודעות: 30816
להורדה ללא רישום
