ג'מיני 3.60
קבצים ולינקים המיועדים ל 7020 ו 7020HD בלבד
הודעות: 30816
Gemini v3.60:
Technical Infos:
* Enigma of: 31.05.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* Upnp Client and Server (for DM500 - DM7000 must be installed from our Gemini-Server)
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* Inadyn (Daemon for different DYNDNS-Services)
* little Apache (HTTP-Server based on HTTPD)
* NFS-Server (based on the NFS-Kernel-Modules)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* JPEG´s ca be rotated and dislaying of the EXIF-Tags (not DM500)
* Support for OGG/Vorbis
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s)
* System Info: Many extra box infos like stream-rates, kernel-, memory- and prozessinfos.
* Own scipts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* Additional EPG-functions (Dishnetwork, cache, storage location)
* Font and Libfribidi e.g. for arabic
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
New:
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
* Calander for iCalander format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc(ical
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
Fix + update:
* see CVS
nterfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background.
להורדה
