Telesat 1.05b Image Released (1W+14W)
vipersvcd
הודעות: 1442
הצטרף: 19 מרץ 2008, 10:05
שליחה על ידי vipersvcd »
1.05b telesat mod
- AutoDetect HW Version (1w/14w) and automatic setting of cfg files
of the appropriate BOX's version;
- Auto-DiSEqC v.1.0 by telesat® , (DiSEqC 1.1/1.2)
You should edit file : /data/sat/diseqc.cfg
Set up DiSEqC type 1.1 or 1.2 according to the system you have
Syntax is <diseqc_type=1.x> where x=1 or x=2 ,
that means that allowed values are:
diseqc_type=1.1 i diseqc_type=1.2
Set up satellite position
Syntax is: <position> <Satname> , where:
<position> = DiSEqC position stored in
DiSEqC positioner or position stored on DiSEqC multiswitch
values must be between 1 and 99, others are ignored
Position 255 in cfg file means that there won't be sent any command on that satellite
<Satname> = name od the satellite - in the way it is written in the box settings file
check with setdir
- Watchdog for OSDshell added
- Transparent OSD
- Telnet password Add
