E2-Board החליף את שמו
yoramro
הודעות: 1278
הצטרף: 04 ספטמבר 2004, 20:00
שליחה על ידי yoramro »
זה העדכון:
Newigma2 - Newigma2 - Newigma2 - Newigma2 - Newigma2 - Newigma2 - Newigma2 - Newigma2
Newnigma 2.1
The Newnigma2-Team presents its new image.
news news news news news news news news news news news news news news news news
NEWS
Many things have changed since the last release of E2-Board Team.
Many things will change in future also.
A new name comes with our new image.
The E2-Board image becomes to Newnigma2 image.
The name of the board changed also:
The E2-Board becomes to Newnigma2 board.
Due to that, board URL changes to:
http://newnigma2.to
Just as ever, best quality and an unpatched image
is our only will to offer.
As DMM changed its CVS to supporting USB devices
by AutoFS, we were able to remove our kernel-patches.
image image image image image image image image image image image image image image
* Dreambox-dvb-modules : 05.06.2008
* Enigma2 : 14.06.2008
* Enigma2-streamproxy : 14.06.2008
* NewNigma2-plugins : 14.06.2008
* NewNigma2-skins : 14.06.2008
changes changes changes changes changes changes changes changes changes changes changes
CHANGES
* We now use std. CVS Kernel. No Patches anymore.
* Due to that, we also have AutoFS in our image.
* New bootlogo.
* Emu startup-scripts have been rewritten.
CA-Display doesn't have to be switched to running emu anymore.
* Installed packets are now displayed in grey fontcolor in online-installer.
* New satellites.xml.
* Name of our menues has been changed to "NewNigma² Service".
* Network Setup in Simatec.chrom Skin changed.
* Standard-Emu in image is now Mgcamd 1.30d.
* HDTV Skins can be used with actual Enigma2.
* German/english NewNigma² languagefile updated.
* Some NewNigma² menue icons updated.
* Minor bugfixes and speedups under the hood.
All questions, tips and improvements:
http://www.newnigma2.to
Your Newnigma2 Team
geosat
הודעות: 1340
הצטרף: 23 דצמבר 2003, 12:30
שליחה על ידי geosat »
חבל על ההתקנה,כי זה עדיין בוסר.
yoramro
הודעות: 1278
אני עובד עם ה Image שלהם כבר חודש בגירסה 2.03.
עובד פרפקט
יורם
geosat
הודעות: 1340
שלום לYPRAMRO
תוכל בבקשה לכתוב איזה מהקמים הבאים ניתן לקבל באימאג' הזה
MGCAMD ?
CCCMD ?
NEWCAMD ?
SCAM[
ואיזה וורסיה הם?
בנוסף האם ניתן להקליט לכונן קשיח USB ,האם ניתן לעשות גבוי?
תודה על התשובה
yoramro
הודעות: 1278
שלום Geosat
מגיע כסטנדרט עם MGCAMD 1.30d
את CCCAM אפשר להוריד
לגבי השאר לא זוכר.
כאשר תוקעים כונן קשיח USB (אני ניסיתי Disk on Key בגודל 4G), הממיר זיהה אותו ללא בעיה. פירמטתי אותו והוא הופך לכונן במערכת לכל דבר - כולל הקלטה וכולל ביצוע גיבויים.
יש כונני USB חיצוניים שצריכת הזרם שלהם גבוהה מדי על ה USB Port בממיר - יתכן שזה מה שעושה לך בעיות. חבר לכונן מקור מתח חיצוני. נתקלתי בתופעה הזו ב DVD עם יציאת USB.
geosat
הודעות: 1340
גם אני בדקתי לגבי דיסק און קי זה עובד
לגבי כונן USB גם עם אספקת זרם חיצוני לא עובד
מסתבר לאחר שבדקתי הGEMINI הוא הכי מתאים, שכללתי קצת את מה ש י.א הציע בקשר לבוקטים קצת מסורבל אבל עובד במו בדרים 500 .
ממלץ לעבור אליו
אולי הכונן הקשיח דורש פירמוט מיוחד אולי?
בענין הבוקטים
בתקיה Bouquets
#NAME Bouquets (TV)
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_hd.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_film.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f1.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f2.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f3.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f4.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f5.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f6.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f7.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f8.tv" ORDER BY bouquet
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites_f9.tv" ORDER BY bouque
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
המשך יבוא
geosat
הודעות: 1340
בתקיה ENIGMA2
userbouquet.favo... 23 01.01.2000... 755
userbouquet.favo... 694 17.06.2008... 625
userbouquet.favo... 347 17.06.2008... 625
userbouquet.favo... 539 17.06.2008... 625
userbouquet.favo... 214 17.06.2008... 625
userbouquet.favo... 137 17.06.2008... 625
userbouquet.favo... 11 17.06.2008... 625
userbouquet.favo... 14 17.06.2008... 625
userbouquet.favo... 10 17.06.2008... 625
userbouquet.favo... 967 17.06.2008... 625
שורה אחת לדוגמה
userbouquet.favourites_2f.tv 141 17.06.2008... 755
userbouquet.favourites_2f.tv זה מקישים
זה כתוב בקיצור וחסר מיספור בתגובה הקודמת
כל קובץ מתחיל כך
#NAME israel
#SERVICE 1:0:1:A:1:0:DE8ABA9:0:0:0:
#SERVICE 1:0:1:14:1:0:DE8ABA9:0:0:0:
#SERVICE 1:0:1:1:1000:2000:DE80000:0:0:0:
#SERVICE 1:0:1:2:1000:2000:DE80000:0:0:0:
#SERVICE 1:0:1:1:B0:B1:DE8AD69:0:0:0:
אם לא מופיעות ה5 שורות אז הבוקט ריק ורואים רק את israel
ובדוגמא זאת מכניסים את הערוצים הישראלי
בוצע על GEMINI
ה usb manager אמור לפרמט את הדיסק בעצמו וזה לוקח די הרבה זמן ולא רואים שזה עובד עד שהוא מסיים.
geosat
הודעות: 1340
אין בגמיני USB MANAGER
ודאי שיש.
geosat
הודעות: 1340
אפשר לקבל הדרכה מדויקת?
תחבר את הדיסק ואז לך ל plugins ותעשה software update. הוא כבר יתקין לך את ה usb manager.
תמתין בסבלנות עד שיסיים את העדכונים.
geosat
הודעות: 1340
זה עשיתי ואין
יש בE-2
בגמיני 3.50 אין חפרתי מכל הכיונים ולא מצאתי
בכל אופן תודה
