Install Evocamd 2.12 Only on your dream and their config files
Modify on your Dreambox in var/keys :
The Camd.cfg file, modify the "Share Mode" line by this :
# share Mode
# 00 Pure emu
# 01 Pure emu
# 02 Pure emu
# 03 alle network clients
# 04 newcamd share
# 05 radegast share
# 06 camd35 share(not in use)
G: { 04 } "put this option"
In the newcamd-client.txt file, put this Line :
[192.168.40.10] "Your PC IP Adress"
port = 6001 (If you have a router, open this port)
key = 01 02 03 04 05 06 07 08 09 10 11 12 13 14
username = dummy
password = dummy
On your PC Now
Launch the SBCL.exe (its a autoextract) c:\SBCL
Put the latest TPS.bin in c:\SBCL\Plugins
Launch the application and modify this :
Client IP is your Dreambox IP Adress
Start your Dreambox and TPS Working
__________________
איך ליפתוח את TPS - עובד ובדוק
thestalker
- הודעות: 2183
- מיקום: ראשל"צ
- Been thanked: 5 פעמים
- dudir
- הודעות: 641
- הצטרף: 09 פברואר 2008, 20:25
