קבוצה רוסית RU DREAM
מוציא בקרוב אימג לדרים 800
IMAGE FOR DM800HD PVR!!!!
dreambox-image-dm800-20090113100113.nfi
md5: 4d421106ffcea7752cd7185ba147cb5f
OE Build Configuration:
BB_VERSION = "1.8.12"
METADATA_BRANCH = "experimental"
METADATA_REVISION = "90cfc96e8cf690961d6033be9b89d2b16b038b71"
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm800"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.6.0"
TARGET_FPU = "soft"
Enigma (CVS 13/01/2009 rumod)
BusyBox v1.01 (2009.01.12-23:19+0000)(rumod)
drivers from 13/01/2009
ruDREAM team & Orbitasat team Wish You Happy New Year and with big pleasure presents the new INNOVATIVE IMAGE for DM800HD PVR
- ruDREAM Infinity!!!
ruDREAM Infinity - no more windows and borders in images!!!
This image for DM800HD PVR based on standard ånigma2 image, with many changes and patches from ruDREAM team.
ruDREAM Infinity presents the revolutionary New Graphic Interface (skin) with new design, with scrolling lines in menus and lists, when showed info is bigger than current fields, and using original solution for cursors to navigate in lists and menus and many other interesting things. We decide to use only HD skins in our images (1280x720) as more perspective and nice.
Some info about image:
Standard infobar, show You info about current channel, now and next event (with scrolling lines in description) picons and info-icons about stream, provider name and orbitral position (last function is switchable on/off in customize menu)
Extended infobar - resolution, current transpoder data (signal quality in db, BER, Frequency, SR, FEC, Polarisation, CAM info, Info about coding)
You can have Extended infobar always on, by swithching it on/off in customize menu.
Function Keys:
1 x OK - Standard infobar
1 Long Press OK - Extended infobar
1 õ BLUE – CAMMD MANAGER
1 Long Press Blue – Extentions
RED – Select Record Mode
Yellow - Timeshift
1 x TEXT - Teletext
1 Long Press TEXT – Subtitles Selection
Downloading Updates, Plugins and Extentions from IPKG MANAGER
ATTENTION!!!
For now some Extentions are not adapted yet for usage in our image. If downloaded Extention dont start or crash enigma2, please be patient and check time to time for adapted version in Download Manager.
All Extentions will be adapded asap
