CCCAM מכה שנית
הודעות: 2791
הצטרף: 25 נובמבר 2006, 18:38
שליחה על ידי prince_amir »
על פי דיווחים אחרונים עולה כי גם הממיר של אוקטגון מספר 918 HD, מכיל בתוכו את הפיצר של CCCAM, מדובר על ממיר עם טיונר של LG, מעבד 1GHZ וכן זכרון של 400MB
על פי האימג האחרון ניתן להריץ CCCAM 2.0.11
-> An elegant HDTV digital satellite receiver
-> With LG tuner, 32-bit 1000 MHz processor and 400 MB of memory provides OCTAGON the HD SF 918 for a strong and first-class reception.
-> Enjoy the HD quality with less than 1 sec switching time of the programmes.
-> With the Ethernet LAN connectivity, USB, eSATA and HDMI, they have the choice of agony
-> Over the remote controlled tuner gain (AGC value) also enables the weak channels without interference to receive this receiver was unique.
-> Individual color settings (brightness, contrast, color saturation) to its Sendungsart (film, news, sports, users) allow them the best image quality.
- LINUX based !!!
Only Arte features:
- 1000 MHz - 32-bit processor
- 400 MB RAM
- 10 000 places (TV & Radio)
- Ethernet LAN - 10/100 Mbps
- E-SATA port
- USB 2.0
- HDMI connector
- VFD display (Dot Matrix Vacuum Fluorescent Display)
- 2 x CI slots for modules
- Universal CONAX Smart Card reader
Features:
- Digital Satellite Receivers MPEG 4/H.264 & DVB-S2 (DVB) compatible
- Format Resolution: 576p/720p/1080i
- 3D user-friendly OSD menu
- Clear and simple on-screen interface
- Color Adjustment: color, brightness, contrast and color saturation
- EPG (electronic program guide) for the display of program information and program preview
- 254 satellite programmable
- Level control DiSEqC 1.0, 1.1, 1.2 and 1.3 (USALS)
- LNB voltage 13/18V & 14/19V adjustable in long lines
- Video format in 4:3, 16:9 and letterbox
- Zoom & pause function
- Recall function: storing the last 20 selected stations
- Find function: stations can be found alphabetically
- Program timer function
- Sleep timer function
- 8 favourite lists for the organization of TV programmes (film, news, sports, music, children, drama, family, Misc.)
- 8 favourite lists for the organization of radio stations (film, news, sports, music, children, drama, family, Misc.)
- Parental Controls for menu and programs
- Several clear channel sorting functions such as delete, rename, move and block
- Backup & restore the setting (Backup / Restore)
- 8 buttons on the front panel
- Front buttons on / off switch
- Support for Teletext and subtitle
- Software - Updates on USB/RS-232 (PC-STB / STB STB)
- Data transfer: receiver to receiver
- Menu in 24 languages
- Games menu: Sokoban, Snake, Tetris, Mines, Slot Machine, Othello
- Calendar and calculator function
- Automatic NTSC / PAL detection
- Very fast channel search
- Multi-Search: several satellites can be marked and searched
- Manual input PID (audio, video and PCR)
- Volume difference for each channel individually adjustable
- Main background and radio background image changed
- Boat image on / off
- Div. Selectable menu animations: Stripe, spray, Slide, Fade
- Power switch on / off
- HF Modualtor
- Dolby Digital 5.1 SPDIF output (optical)
- 2 x Scart (TV / CVR)
- 2 x RCA audio output (R / L)
- 1 x RCA video output
- Component output (YUV - YPbPr)
- Dimensions: 340 x 60 x 268 mm
- Weight: about 2.5 kg
עלות הממיר 260 יורו
tiptip
הודעות: 1691
הצטרף: 15 מאי 2007, 20:29
שליחה על ידי tiptip »
תודה רבה נראה מבטיח
dream 800 hd
26E 19.2E 16E 13E 7E
9E 5E 4W 7w
אור שפע ואהבה!!!
sickboy666
הודעות: 1564
הצטרף: 14 יוני 2006, 00:26
שליחה על ידי sickboy666 »
מה זה אמור להיות? קורא כרטיסים רק ל CONAX? :huh:
ariel
הודעות: 1419
הצטרף: 24 דצמבר 2003, 11:02
שליחה על ידי ariel »
יפה מאוד
נקווה שבקרוב גם ב ipbox
אריאל
TV_Eye
הודעות: 97
הצטרף: 13 מאי 2009, 11:40
שליחה על ידי TV_Eye »
ותמכור ? אטרקטיבי?
הודעות: 2791
260 יורו
