כרטיסים -מחירים ותכונות:
(SKYSTAR, BROADLOGIC, TWINHAN, WINTV)
(אם מישהו מכיר עוד כרטיסים נפוצים או תכונות נוספות מוזמן לשלוח כתוספת לנושא הזה)
SkyStar 2.6b - New Version
http://www.technisat.com/
יש אפשרות לשלט בדגמים יותר חדשים
עולה בסביבות
EURO 55
(פחות או יותר)
Recommended Hardware:
TV reception: Intel PIII 700 MHz
128 MB RAM
Data reception only: Intel PIII 500 MHz
64 MB RAM
Reception of digital data services via satellite
Data streams of up to 90 Mbps
Reception of digital satellite TV and radio programs
Recording opportunity with video recorder function (PVR)
Pre-programmed program list
Video text
Plug & Play enabled
Input frequency range 950 MHz - 2.150 MHz
Symbol rate 2-45 MS/sec., SCPC and MCPC
Operating system WIN 98 SE, WIN ME, Windows 2000 Professional/Server, Windows XP Home/Professional, Windows 2003 Server
Made in Germany
Tuner input: F-connector
Input impedance: 75 Ohm
Demodulation: QPSK
Viterbi rates: 1/2, 2/3, 3/4, 5/6, 7/8, automatic adjustment
LNC control: 14/18 Volt for polarisation switching
22 kHz and DiSEqC 1.0 for switching frequency range
IF-Bandwidth: 36 MHz
Operating systems: Win 98 SE, Win 2000, Windows XP
System requirements:
PC with Pentium II 266 MHz and 32 MB RAM (or higher) for data applications
PC with Pentium II 350 MHz and 64 MB RAM (or higher) for TV applications
PCI or AGP graphics with min. 8 MB RAM and motion compensation, 3-D support
TWINHAN - VisionDTV -Sat
עולה בסביבות 110$
יש אפשרות לשלט
Key Features
Support DVB protocol
Support DVB Data Broadcasting(ETSI301 192)
Support MPE (multiprotocol encapsulation)
Digital Satellite TV and Radio Program Receiving
Real time Digital Video Recording (DVR) and Scheduling Recording
Time-shifting
Electronic Program Guide (EPG)
Still Frame Capture
FTA Multi-Channel Preview
Transponder, Satellite Auto Scan
Viewing and Schedule Recording Different DTV Channels Simultaneously
MPEG-II Software Decoding
Software Upgradeable
Video Quality Adjustment
Favorite List
Teletext
System Requirements
Windows 98SE/ME/2000/XP
500MHz CPU or above
128M RAM or above
VGA Card with at least 8MB Memory
Sound Card
Microsoft Direct X 8.1 or above
Digital Satellite Dish & LNB
Tuner
Input terminal: F-type 75 Ohm
Receiving frequency: 950~2150 MHz tuning range
Input level: -65~-25dBm
Support MCPC and SCPC
QPSK & FEC
Symbol rate: 2~45Msps
QPSK filter: Root-raised cosine filter with roll-off 0.35
FEC: 1/2,2/3,3/4,5/6,7/8 and Auto
LNB & Switch control
LNB supply voltage: 13V/18V
DiSEqC: 1.2
Support Data Burst & Tone Burst
Antenna and LNB control: 22KHz Tone
Max. LNB supply current: 400mA with short circuit and surge protection
Demultiplexing
Max No. Section filtering: 32PIDs
Engine: software
Stream capture: PES & TS
A/V Format
Video format: MPEG-II Main Profile& Main Level
Audio format: MPEG-II Audio layer I & II
Hauppauge WinTV Nexus-s
http://www.hauppauge.co.uk/html/digitaltv_prod.htm
יש אפשרות ל
CI INTERFACE
יש אפשרות לשלט
עולה בסביבות
95EURO
Compatibility :
To use the WinTV Nexus-s card, you will need the following:
PC with Pentium II Processor, (minimum 266Mhz)
32 MB RAM minimum
PCI or AGP Graphics card, running at a minimum resolution of 800 x 600 Pixel,
Microsoft Windows 95 / 98 / 2000 / XP
If you have a 400MHz Pentium II or faster, you can use Nexus-s to display TV while still running other PC's applications
Connectors on the WinTV Nexus-s PCI card:
LNB - F-Connector socket Signal input from your digital satellite system
(check 'Compatibility' section, above).
2.5mmm connector for Remote Control
Audio line-out to connect to line-in of soundcard or active speakers.
Connection via ribbon cable for Common Interface Module
(sold separately)
Personal Digital VCR
Compression Mpeg-2: Compression MPEG-2 allows the recording in complete screen
BROADLOGIC 2030Satellite Express PCI+
http://www.vboxcomm.com/
יש אפשרות ל
CI INTERFACE
עולה בסביבות 30$
External Connectors: F type female
Receiving Frequency: 950 MHz to 2150 MHz
Input Signal Level: -65 dBm to -25 dBm
Nominal Input Impedance: 75§
L/O Leakage at RF Input: -63
Windows 98, 2000, XP and Various Linux Versions
FEC
Decoding: Viterbi/Reed-Solomon
Viterbi Inner Code:
K=7, R=1/2, 2/3, 3/4, 5/6, 7/8
Reed-Solomon Outer Code: (204, 188)
Software Capabilities
UDP/TCP/IP Protocol
PES and TS Data Filtering
PSI/SI Private Tables
LLC SNAP/Null Encapsulation
Single or Multiple Board Support
Single and Multiple Application Support
Downloadable Firmware
Transponder Settings
Polarization, Symbol Rate, Frequency
Tuner Status
Signal Strength
Signal Lock
Error Status: Channel BER, Virterbi BER,
Reed-Solomon, LNB Offset Frequency
Signal to Noise Ratio
QPSK
Symbol Rates: 1.5 - 45 Msps - variable
LNB Power and Switching
Supply Voltage: Selectable 13V or 18V
Max LNB Current: 400 mA
Antenna Control: 22 kHz signal
Short Circuit Protection
LNB Settings
Local Oscillator Frequency
Hardware Capabilities
Multiprotocol Encapsulation (MPE)
Datagram and Section Packing
No ECM, EMM to the bus
CRC Check Sum
Unicast/Multicast Filtering
MAC Addresses: 128
PID Filters: 8
Section Filters: 32
Optional Connectors
Smart Card reader
26-pin LVDS Connector
דגמים נוספים : מחירים
Technotrend Dvb s budget 2 CI Common interface 105 EURO
Typhoon TV SAT Dvb s Card
80 EURO
Pinnacle PCTV
60 EURO
כרטיסים-מחירים ותכונות:(SKYSTAR, BROADLOGIC, TWINHAN, WINTV)
- איש המציאות
- הודעות: 792
- הצטרף: 23 דצמבר 2003, 09:33
- מיקום: חיפה
my collection so far :
