PKT mod 7.0 Tideglo rev 0.7.0
- edilit
- הודעות: 436
- הצטרף: 26 נובמבר 2005, 14:00
				DJ
- הודעות: 732
- הצטרף: 23 ספטמבר 2004, 18:08
- מיקום: תל אביב
- edilit
- הודעות: 436
אני מתקין עם תוחנה מצורפת
תרגום מרוסיט
/ SETUP /
1) select the profile
At different firmware - different passwords. Therefore made presets.
You can edit the password in the program itself, and in the ini-file.
Prescribes the same ip-address of your receiver. Data saved in ini.
2) click the button [connect telnet]
if everything is configured correctly then the 3 red rectangle will turn green.
A sample log of these transactions:
connect to 192.168.1.4
Disk / dev / sda: 320.0 GB, 320072933376 bytes
Disk / dev / sdb: 1967 MB, 1967128576 bytes
If the third box does not turn on the green, then either the wrong password, or any non-standard invitation system. Click the buffer and see the latest posts from the receiver. Copy the log to the forum, with an indication of the model receiver firmware version. Or try to set themselves the option prompt = xxxxx, where XXXXX - prompt your receiver (copy only the central, immutable part).
/ FORMAT /
3) select the Device
Do not forget to Save Settings receiver via BOOKMARK BACKUP
then press the button on the next 1 - 2 - 3 - 4
umount. It is necessary for operations with flash drives (or drive). If successful dismantlement is written Ok, a failed - error. Follow logom.
fdisk. This operation removes all marked up with the disk and creates a new (yet another). You can not break the disk, if the partition where you will install a Linux firmware format as well as a sign of "active".
fdisk.pro additional function of the breakdown of large disks. When, for example hard disk is divided into 2 sections (1-swap, 2-data), but must still fill the firmware on the hard disk. If you fill in section 2, it will spoil the standard firmware. Therefore, through this function creates a disk 3 (sda3) size 1 gigabyte. Thus the data from section 2 is destroyed!
Function of demand is available only if the disk size is large enough.
format. In preparation filesystem. Need to do it through the receiver. Only in this way is guaranteed by downloading firmware.
mount. Connect the device to the system receiver and mounted folder. (4 th pryamouglnik becomes green). This operation is required, because All control commands receiver invoked that Mount device. To work with internal firmware (or current, regardless of internal or external), use the disk root.
Version log:
fdisk / dev / sdb. . . . . . . . . . . . . .
Fdisk is ok
Ok
Writing inode tables: 0 / 15 ????? 1 / 15 ?????
/ INSTALL /
Last necessary operations:
open e2. Choose which lies with the firmware archive (tar or gz)
copy. Copied firmware from FTP to the receiver (on the device, which is produced). If the receiver hangs on this surgery, it is possible that a new mount the partition is not formatted properly. Try to repeat the operation for mounting.
unpack. Extract firmware
flash. Sews internal receiver firmware or multiboot. To do this, load into the receiver fayl.img and press the button. This function works through a script update.sh, guaranteed work at sif, nlb, ufm modifications.
addons. Online downloading patches and add-ons. Choose the necessary patch, bet on it tick, and then click PATCH, and you're done. The file is downloaded directly to your receiver, unpacked and installed. For installation instructions for modifying multibuta internal firmware, use the disk root.
Version log:
File: Ip-Box-AAF-RisingSun-9000HD.tar.gz
Connecting to 192.168.1.4:21
C: \ SAT \ Enigma \ Ip-Box-AAF-RisingSun-9000HD.tar.gz write ...
Transfert succesful. File is C: \ SAT \ Enigma \ Ip-Box-AAF-RisingSun-9000HD.tar.gz.
The process of unpacking (and up) may take a long time.
/ E2 /
In this section you can adjust the network settings, and equipment.
correct ip - fixed settings for the network. Installs IP (which is used for communication with the receiver), configured nameserver
correct fstab - corrected the settings for hard disk partition system. Settings are written to the installed hard disk or flash (sda1 = swap, sda2 = hdd);
Video: HDMI - prescribed video output settings to HDMI
Video: SCART - prescribed options for video output SCART
Video: SD - set video output for SD TVs.
Patch YUV - allows you to use component output.
Save & Restart - save the settings and restart your receiver (if loaded with enigmy2. If the normal firmware - not necessarily push).
/ BACKUP /
In this section, you can save some receiver settings, if you upgrade your version of the Enigma. There are still files in the folder / var / config - 2 units and from / usr/local/share/enigma2 recorded base, channel lists, settings DISEqC etc. These settings are valid for Enigma2 (author ISCAN) and partly true for Enigma2 AAF (not save the settings for network balloons).
backup - save your settings into an archive. (file bck.tar.gz stored in a folder with the program enigma setup.
restore - restore settings from the archive.
save & restart - to save the settings (which booted the button restore) and overload the receiver. Need to click, if you are booted by Enigma machine and it also restore the data. Since otherwise, restore the previous settings.
Optionally you can also save the settings EMU from the folder / var / keys, as well as additional configuration files.
Added option for bakapa their files. Introduce the full path. Files separated by spaces (example: "/ etc/my_file_1 / var/my_file_2"). Active only with a check mark "additional files".
Preserve and restore data from the receiver should, after binding clicking 'MOUNT'. What would all the files were restored to their waterways.
/ MULTIBOOT /
Now you can change the loader in the receiver. You have to understand what to do, because thing honest.
To begin installing multibut official - for multiboot. Then the firmware patch rolls mboot.tar.gz - for the possibility of changing multibuta. Only after this change the boot "for themselves. Choose a device with a load, the button on the remote, and the port (if yuzb). Then the button apply.
On a standard boot loader from the following options:
Network booting CDKroot
boot from USB device (during a sata HDD)
with internal Flash *
Network booting
boot from USB (without fixed SATA HDD)
boot from SATA HDD
booting from internal flash to another image
Therefore, the preferred options for changing the boot: 2, 4, 5, 6. Do not change the 3rd option, otherwise boot. Why enigma-setup all the options available? - Because a lot of options downloaders. There is a (first) multibuty that use variants 1-4 and all.
Options network settings: Set the receiver's ip address, gateway, server, press SET. Propishutsya ONLY network settings, without changing the settings multibuta. For what would the network settings to work, loading the receiver again choose multibut (retention resp. Button on the remote). Then the address will be used.
						תרגום מרוסיט
/ SETUP /
/ FORMAT /
Version log:
Fdisk is ok
Ok
/ INSTALL /
Version log:
/ E2 /
/ BACKUP /
/ MULTIBOOT /
Network booting
boot from SATA HDD
				mikiha
- הודעות: 151
- הצטרף: 23 אוגוסט 2009, 01:07
