Originariamente inviata da ReadMe
HISTORY:
release 0.8.5
- fixed AC3 audio dropouts over SPDIF with downmix set to off on few HD channels (report if the bug still there on some channels)
- fixed the enable/disable 12v option in advanced enigma2 menu configuration
- fixed a high cpu usage bug on enigma2
- fixed pgup and pgdown buttons, now they are mapped to be used for channel changing
- added possibility to change bootlogo on flash images
- fixed a bug on few receivers that on 0.8.0 made them not working
- fixed a stability bug on all receivers
- fixed bug on the second tuner for scrambled channels
- added NTSC, 480i and 480p video modes support (i don't know if it works or not, i can't test it)
To people having problem with date/time:
since version 0.8.0 date/time is managed on the same way used on DGS firmwares, so if you at first are having a bad value
for date/time, just go into telnet console and type the command: date -s YYYY.MM.DD-hh:mm:ss
Replace YYYY with the year, MM with month, DD with day, hh with hour, mm with minute, ss with seconds.
After this type: cubefpctl --syncfptime
Now set your GMT offset on enigma2 configuration menu.
WARNING: using PIP with the second tuner on scrambled channel could make the tuner stops to work,
a full box restart is needed to make it working again.
I will try to fix this on next versions.
Enjoy it! Tideglo
http://enigma2.sifteam.eu/index.php?dir ... d%200.8.5/
						Enigma 2 Nightly Build: 0.8.5 version
- הודעות: 2791
- marcelos
- הודעות: 1028
- הצטרף: 11 פברואר 2005, 09:54
- מיקום: קרוב, בסביבה
