| PGI v1.1, Kamakiras |
| based on CRD 13759 |
THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. UNDER NO CIRCUMSTANCES WILL THE PGI SOFTWARE AUTHORS BE LIABLE FOR ANY INDIRECT, INCIDENTAL, CONSEQUENTIAL, SPECIAL OR EXEMPLARY DAMAGES, DATA LOSS OR HARDWARE MALFUNCTION, ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE UNDER NEGLIGENCE OR EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. BY INSTALLING AND USING THE SOFTWARE YOU ACCEPT ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
Change List for PGI 1.1
- New: picons support (see new option in pgi.conf called PICONS below)
- New: allow the power popup when a recording is active, only shows the sleep timer when a recording is active, other options are not shown
- New: added "Default Power Control" option to PVR Settings which applies the selected value to the power control of all instant recordings and timers
- New: fast forward and rewind in the MP3 player; short press goes to next/previous track, longer press does FF/REW, speed increases if the button is held longer
- New: MP3 player can now play unlimited file size, file size was originally limited to the amount of free memory
- New: support for retail 100HD model RCU (the older RCU is possible to enable via pgi.conf OLD_REMOTE option)
- New: Hebrew language added
- Fix: CI modules crashes
- Fix: crash in the settings wizard on first boot
- Fix: initial wizard would run many times even after channel scan and reboot
- Fix: sometimes there would be no video/audio until channel change after stopping the timeshift
- Fix: DiSeqC settings are now reset when adding the next LNB in fixed Sat
- Fix: corrected multiboot for USB/sda options
- Fix: deleting last recording caused wrong OSD information
- Fix: crashes on shutdown while fetching EPG
- Fix: startup scripts corrections for boxes without CI modules
- Fix: changing audio tracks when watching recordings did not always work
- Fix: optimisations in EPG handling and related stability fixes
- Update: updated Web interface, SQLite and BusyBox libraries to the latest versions
The images can be downloaded from myipbox.info or wait till they are uploaded here at denktenk.com
http://www.mediafire.com/?mgpmzveiy48y0hd
