מה ההבדל?
nati777
- הודעות: 1500
- הצטרף: 09 מאי 2011, 22:28
- מיקום: קרית גת
nati777
- הודעות: 1500
- מיקום: קרית גת
Re: מה ההבדל?
A number of versions of DiSEqC exist:
DiSEqC 1.0, which allows switching between up to 4 satellite sources
DiSEqC 1.1, which allows switching between up to 16 sources
DiSEqC 1.2, which allows switching between up to 16 sources, and control of a single axis satellite motor
DiSEqC 2.0, which adds bi-directional communications to DiSEqC 1.0
DiSEqC 2.1, which adds bi-directional communications to DiSEqC 1.1
DiSEqC 2.2, which adds bi-directional communications to DiSEqC 1.2
All four[clarification needed - there are 6; to which 4 does this refer?] variations were standardized by February 1998, prior to general use of digital satellite television. The later versions are backwards compatible with the lower revisions, but the lower revisions are, as might be expected, not forwards compatible with the higher revision numbers. 1.x and 2.x versions are both backwards and forwards compatible.
The terms DiSEqC 1.3 and 2.3 are also often used by manufacturers and retailers to refer to the use of DiSEqC with other protocols. For example, 1.3 usually refers to a receiver which uses USALS in conjunction with the DiSEqC 1.2 protocol. Such terminology has not been authorised by Eutelsat.
- mola10
- הודעות: 2405
- הצטרף: 30 מרץ 2006, 12:09
- הודעות: 30827
Re: מה ההבדל?
ובכלל הגיע הזמן שnati777 יעביר את השאלות הבסיסיות האלה למדור המתחילים!!!
ועוד דבר - מתי תלמד להשתמש בגוגל???!!!
