LNB חדש
mbd
הודעות: 657
הצטרף: 08 דצמבר 2009, 14:48
LNB חדש
שליחה על ידי mbd »
S.E.S ושותפות הודיעו היום על LNB חדש שעומד לשנות הרבה דברים בענף הלווינים.
SES launches industry’s first IP-LNB
April 23, 2013 07.29 Europe/London By Robert Briel
SES, Inverto, Abilis and MaxLinear have announced the industry’s first IP-LNB.
The companies have been jointly designing an essential component for cost-effective IP distribution of satellite television to the home – the first low-noise block down-converter (LNB) that will incorporate eight-channel satellite-to-IP bridging technology.
The IP-LNB is a prototype device that will deliver eight concurrent channels from any of the transponders of a satellite orbital position. These channels may be forwarded via IP unicast or multicast to fixed and portable devices. Satellite signals will be distributed via Ethernet, power-line communications (PLC) or a Wi-Fi local area network (LAN). The technology can be used for free-to-air or pay-TV applications.
“The IP-LNB will give satellite television providers and consumers new options for distributing unmatched quality satellite television to multiple TVs, computers and tablets over IP at the lowest cost,” said Thomas Wrede, VP, SES reception systems.
“When we committed ourselves to making SAT>IP an open standard, we envisioned this type of innovation. It is exciting to see it now come to fruition.”
The LNB is a crucial element of a satellite system, receiving signals collected by the satellite dish, amplifying and converting them to intermediate frequencies to be carried to the set-top box (STB).
By locating the satellite reception and the IP bridging functions in the antenna the IP-LNB will enable satellite content distribution to the home over a single Ethernet cable. The IP-LNB may be powered over that same cable through Power over Ethernet (PoE) technology, greatly reducing the overall system cost and power consumption.
This new technology enables the satellite signal to be sampled digitally directly at the antenna, making the satellite spectrum data and other link-quality metrics accessible over the LAN. These advancements greatly simplify the dish installation and enable remote monitoring from the LAN.
Designing such a novel LNB requires significant advances in satellite chipset and real-time IP streaming software technology in order to meet the unique system requirements on the size, power consumption, long-term reliability and price point required for a commercially viable outdoor unit (ODU).
The new device will combine SES’ SAT>IP protocol innovations, MaxLinear’s Full-Spectrum Capture DVB-S2 receiver IC, Abilis’ TB101 Broadcast to Broadband Bridge SoC, and Inverto’s software stacks and a new high-performance LNB product design. Together, these technologies have produced a compact, cost effective and low-power eight-channel IP-LNB.
Re: LNB חדש
אז צריך להתחיל להעביר כבל רשת לגג
mbd
הודעות: 657
Re: LNB חדש
שליחה על ידי mbd »
כן אבל כל מי שיתקין IP-LNB לא צריך אף כבל אחר
והיתרונות ברורים ומרובים.
Re: LNB חדש
אפשר לקבל תירגום?
mbd
הודעות: 657
Re: LNB חדש
שליחה על ידי mbd »
הטכנאי קרמר כתב:אפשר לקבל תירגום?
תירגום חופשי ובקצרה
כמה חברות מובילות בענף הלווינים פיתחו ביחד
LNB-IP [SAT-IP
חדש שעובד בצורה מיוחדת הוא מכיל בתוכו צ"יפ
מעבד שמסוגל לתרגם את אותות הלווין לאותות
רשת ולהעביר אותם לבית והכל נעשה בצורה דיגיטלית
ללא שום הפסד או שינוי באות מה ששומר על איכות גבוהה
כל הזמן זה מתחבר ע"י כבל רשת ולא ע"י כבל לווין רגיל
זה מסוגל להעביר 8 ערוצים באותו זמן מאותו טרנספונדר
מכל לווין שמחובר ובבית כל מכשיר שמסוגל להתחבר לרשת
בחיבור קווי או בחיבור אלחוטי יכול לקבל את האות כלומר
לשמש בתור ממיר ומסך באותו זמן זה אומר שכל טלוויזיה
מחשב שולחני או נייד -פלאפון -סטרימר קונסולת מישחקים
טבלט או כל מוצר אחר שיכול להתחבר לרשת יכול לצפות
בשידורי הלווין ובערוצים שונים באותו זמן במסגרת הרשת
הביתית וכל האותות מוגנים זה יכול להעביר שידורים חופשיים
או שידורים מקודדים כרגע אף אחד לא יודע מה הם יעשו בקשר
לפתיחת ערוצים מקודדים היות וזה לא מכיל קאם אבל אני מניח
שגם לזה יש להם פיתרון
בנוסף היות והאות עובר לבית בצורה דיגיטלית אפשר לראות
במחשב אם הלווין מכוון בצורה אופטימלית בעזרת ספקטרום
אנלייזר שבנוי לתוך המעבד
מקווה שעזרתי לך להבין את עיקר הדברים
Re: LNB חדש
זה כבר לא יהייה בדור שלי השימוש
geostant
הודעות: 1037
הצטרף: 23 ינואר 2004, 15:28
מיקום: אינו מוגדר
Re: LNB חדש
שליחה על ידי geostant »
INVERTO הציגו את הפתרון הזה בתערוכת ANGA בשנה שעברה
יש לי יחידה אחת כזאת במשרד
aela
הודעות: 569
הצטרף: 28 אפריל 2004, 21:13
Re: LNB חדש
שליחה על ידי aela »
geostant כתב:INVERTO הציגו את הפתרון הזה בתערוכת ANGA בשנה שעברה
אבל שיתוף אי אפשר לראות עם זה ?
dr.jalalsat
הודעות: 2
הצטרף: 04 מאי 2013, 19:09
Re: LNB חדש
שליחה על ידי dr.jalalsat »
thanks alot....................
