What's New v2.5 (28.12.2013)
Some channel scan bugs fixed
Fixed the problem with DVB-S2 channels not tuning on TBS cards
Fixed a freezing problem with deleting channels (affected Windows 8 users mostly)
Fixed EPGParser bug which causes freezings time to time(i.e. on Eutelsat 9A, 12034 V)
TBS remote control fix
Bug fixes for several TBS DVB-S2 models
Supports new TBS cards
Estonian language have been added
* New theme: Yusuke Kamiyamane & Redeemer
* If you use Windows 8 or if you have no video or video problems on Windows 7/XP, then please make sure you install codecs since Windows 8 doesn't include required codecs. You can find most of codecs by a simple google sarch, search and download "dvbdream codecs" on google or just click here. After installing new codecs, you should restart DVB Dream and select them (Main Menu->Options->Video or simply press CTRL+G). Some of the codecs will work better than others, depending on your system configuration.
הורדה:
http://rghost.net/51268542
