מכשיר חדש באריזה מחיר 1800לאחר מכס ועמלות שחרור
כולל ספקטרום לפי לווין וסריקה לווינית וקרקעית
מפרט טכני:
1.DVB-S2  DVB-T2 HD Mpeg4   combo terrestrial signal meter finder
satellite meter finder meter
2. spectrum  constellation
3.Meter for Signal
4.multimedia
5.systme
Open the package and make sure it includes all below items, if anything is missing, please contact the reseller for replacement.
Digital Satellite Meter
User’s manual
AV cable
Car charger cable
Adaptor
Carrying bag
Silicone case
TRANSMISSION STANDARDS
DVB-S/S2,DVB-T/T2
DVB-T/T2  INPUT/DEMODULATION
Connector Type
IEC Female 9.5mm /FEMALE  Type
Input Frequency
48 to 862 MHz
Signal Input Level
-79.5 dBm (MAX)
ANT  Supply
5V/12V/17V, IMax 100mA
Demodulation Type
QPSK,16QAM,64QAM,256QAM
DVB-S/S2 INPUT/DEMODULATION
Connector Type
F Type
Input Frequency
950 to 2150 MHz
Signal Input Level
- 65 to -25 dBm
Band Switch Control
22KHz
LNB Supply
13V/18V, IMax 400mA
Demodulation Type
QPSK,8PSK,16APSK
Symbol Rate
2<Rs<45 M band(SCPC/MCPC)
LCD FEATURES
LCD Type
TFT TRANSMISSIVE
Number of Dots
480(RGB) x272
Active area (W x H)
95.04x53.86 mm2
AV out/input interface
Connector Type
3.5 mm jack
Video
CVBS,
Audio
Stereo Audio L/R output
AUDIO/VIDEO PROCESSING
Resolving rate
PAL-25 frame@720*576,NTSC-30 frame@720*480,
Signal compatibility
Support conversion for different video formats
Video Format
4:3,16:9,By Pan & Scan and Letter Box conversion
Audio output mode
Stereo, Mono, R/L
DATA SERVICE PORT
Connector
USB
Data protocol
USB2.0 interface
file format
mp3,jpg
MICROPROCESSOR
Microprocessor
Amlogic
Clock Frequency
180MHz
SDRAM Memory
512Mbit
Power SUPPLY
Li_Ion Battery
7.4V/3000mAh
