MMOexp Lineage 2M: How to Shadowstrike Through Antharas Awakening
לוח יד שנייה לפרסום מודעות "למכירה" או בקשות חיפוש, לציוד לוויני משומש מכל סוג. המדור אינו מיועד לחנויות/יבואנים.
Lilidala
הודעות: 3
הצטרף: 12 פברואר 2026, 10:17
שליחה על ידי Lilidala »
In the vast and dangerous world of Lineage 2M, few threats compare to the might of Antharas, the legendary Earth Dragon. As one of the game's most formidable world bosses, Antharas poses a significant challenge to even the most experienced adventurers. In Shadowstrike of the Antharas Awakening, players who favor swift, lethal attacks and tactical positioning—particularly those using Shadowstrike—can rise to the occasion and Lineage 2M Diamonds strike a deadly blow from the shadows.
This guide will walk you through building an effective Shadowstrike assassin and preparing to face the awakened form of Antharas with confidence and precision.
Mastering Shadowstrike: The Assassin’s Signature Move
Shadowstrike is a potent rogue skill that epitomizes precision damage and stealth. Available to classes like Abyss Walker or Treasure Hunter, this ability focuses on dealing heavy critical strikes from behind or out of stealth, ideal for both PvE boss fights and PvP ambushes.
Core Mechanics:
Type: Melee active skill
Effect: Delivers massive backstab damage with increased crit chance
Perks: Bypasses a portion of enemy defense; high burst potential
Cooldown: Balanced; short enough to use multiple times per boss phase
It’s a skill designed for players who excel at timing, positioning, and surgical strikes during chaotic battles.
Building Your Shadowstrike Assassin
A successful Shadowstrike build focuses on speed, critical hit rate, and evasive agility. Your goal is to dive in, strike hard, and escape before retaliation.
Class Progression:
Start with the Rogue base class
Specialize into Treasure Hunter or Abyss Walker
Focus on passives that increase stealth duration, crit rate, and movement speed
Stat Priorities:
DEX for accuracy and evasion
STR for increased melee power and crit damage
AGI for faster skill cooldowns and movement
Recommended Gear:
Weapons: High-crit daggers or dual blades such as the Silent Fang
Armor: Light armor sets with evasion, movement speed, and stealth bonuses
Accessories: Use crit-enhancing rings and cooldown reduction items
Enchants: Prioritize backstab damage and critical rate improvements
Preparing for the Antharas Awakening Encounter
Antharas isn’t just another boss — he’s a world-ending force. When he awakens in the Dragon Valley Core, your team must be well-geared, highly coordinated, and fast to react.
Minimum Requirements:
Level 55+ character
Enhanced equipment (+6 or better)
Access to Dragon Valley Dungeon – Core Chamber
Awareness of global spawn timers for Antharas Awakening events
Antharas Mechanics Breakdown
Antharas’ fight is split into distinct phases, each presenting unique hazards. Reacting appropriately to each mechanic can mean the difference between victory and a wipe.
Phase 1: Earthquake Shockwaves
Giant AoE slams deal heavy earth damage
Position around his flanks to avoid direct hits
Use mobility skills to dodge and reposition
Phase 2: Stone Golem Summons
Golems spawn in waves to protect Antharas
Prioritize ranged and healer-type golems
Shadowstrike is excellent for sniping key targets during this phase
Phase 3: Awakened Rage
At 30% HP, Antharas enters an enraged state
All attacks are faster and deadlier
He unleashes Roar of Destruction, a massive AoE that can kill if not dodged
Assassin Strategy: Shadowstrike in Action
Here’s how to leverage Shadowstrike in each phase for maximum impact:
Engagement:
Use stealth or evasion skills to close in without drawing aggro
Time your Shadowstrike for when crit buffs or debuffs are active on the boss
Hit from behind to trigger maximum damage potential
During the Fight:
Wait for openings between Antharas’ AoE attacks to move in
Chain Shadowstrike with evasion or retreat abilities to minimize risk
Use cooldown potions to maximize uptime on Shadowstrike
Mob Phase Tactics:
Quickly eliminate stone golems to reduce pressure on your team
Shadowstrike can one-shot key minions if timed correctly
Avoid getting surrounded — always plan your escape route
Teamplay Tips
Tanks should position Antharas so assassins have clear access to his rear
Healers need to stay mobile to follow fast-moving DPS
Communicate cooldown rotations and alert teammates when the rage phase begins
Assign Shadowstrike users to minion control when needed
Loot and Long-Term Gains
Victory against Antharas can earn you:
Antharas Ring – A powerful crit-based accessory
Dragon Scale Materials for crafting rare gear
Blueprints for assassin-focused weapons
Earth Essence Crystals to enhance Earth resistance or backstab damage
The Antharas Cloak, a rare drop, grants stealth-related bonuses and is highly sought-after by rogue classes.
Conclusion: Become the Shadow That Slays the Dragon
Lineage 2M: Shadowstrike of the Antharas Awakening is a high-stakes challenge where speed, precision, and strategy come together. The rogue classes excel in this fight, weaving through danger and delivering fatal strikes. Shadowstrike is more than just a skill — it's a statement of dominance in the art of assassination.
If you’re ready to step into the shadows and cheap Lineage 2M Diamonds take on one of the game’s greatest foes, this is your moment. Build wisely, strike decisively, and let the legend of your blade echo through the depths of Dragon Valley.
